Windows 7: System Protection - Turn On or Off
05 Sep 2012   #60
Brink
64-bit Windows 10 Pro
Hello Robert, and welcome to Seven Forums.
Are you dual booting with another OS?
Do you have all Windows Updates installed to have Windows 7 fully up to date?
In addition, check: System Restore points are deleted after you restart your Windows 7-based computer
....and if you have enough max space set for restore points.
System Protection - Change Disk Space Usage
Hope this helps for now,
22 Feb 2015   #61
Scoop
Windows 7 Home Premium 64 bit
Shawn,
I'm running Win 7x64 OEM version on a built Desktop PC w/Asus MoBo. My C HDD is a 1 Tb size with about 115 Gb used space at present.
I've been seeing a strange issue with my "C" OS drive where the Protection is getting switched to "off" mode. I just started to track the problem to see what may be happening but here's what I've seen recently.
When I installed this month's Windows "Patch Tuesday" updates, all went ok. I saw the normal "Creating a Restore Point" dialog appear before the updates began installing. I'm assuming at that time that my "C" HDD Protection State was in an "on" state. Perhaps that's not accurate to assume that but since the Restore Points appeared to be created by the WU process, I'm thinking that this was the case at that time.
Yesterday, Sat 02/21 U.S. time, I encountered an unrelated issue with Norton AV where my IE11 was inaccessible (this made a lot of "buzz" news around the 'net since Fri 02/20 evening U.S. time; Norton has since fixed the issue). The issue with Norton prompted me to look at my Restore Point selection dialog but to my surprise, there were no Restore Points present. I saw the "error" dialog that's been mentioned earlier in this thread.
When I checked my "Protection" tab, my C HDD Protection was "off". I changed it to "on" and manually created a Restore Point without issue but I've seen this happen several times over the last 2-3 years where it seems that my C HDD Protection State is being toggled off for some reason. I never think to check the Protection state on my C drive until I'm looking at the Restore Points selection dialog.
Have you heard of this issue occurring with other Win 7 users?
I am a frequent HDD Cloner so I wonder if that's causing this issue? That wouldn't be my first guess but I'm probably Cloning and Imaging more frequently than some other Win 7 users.
22 Feb 2015   #62
Brink
Hey Scoop,
Norton has been known to cause several issues at time with Windows. You might completely uninstall Norton as a test to see if your system protection continues to get turned off.
https://support.norton.com/sp/en/us/...rProfile_en_us
23 Feb 2015   #63
Scoop
Shawn, thanks for the suggestion. I've been thinking about that, installing another AV to use as a troubleshooting tool to eliminate Norton when questions like this one arise.
Windows Defender Real-Time Protection - Turn On or Off
How to Turn Windows Defender Real-Time Protection On or Off in Windows 7 Windows Defender real-time spyware protection runs in the background and alerts you when spyware and other potentially unwanted software attempts to install itself or run on your computer. This will show you how to...
Tutorials
Wordpad: how to turn off hyperlink protection question
Hello Maybe not the proper forum to ask, but I have no other clue where look for Using Wordpad, how can I remove the protection question: everytime I click on an hyperlink? Martin
General Discussion
Can I turn on system protection thru cmd? Windows is frozen.
I think that I have some "corrupt files" that were deleted after some auto updates were installed. This has created chaos in my windows. Normal mode windows locks up when booted, and now it is doing the same thing in safe mode. The only response I can get is in command. I also tried...
General Discussion
System Protection will not turn on
I recently had a power outage while Windows 7 (x64) was loading. System booted up fine. I went to do a system restore, but could not. When I go to select a restore point is says, "System Protection is turned off". I never turned it off and it will not let me turn it on. The C:\ clearly shows...
General Discussion
How to Turn Off System Protection by registry (regedit)
Is there any way to disable System Protection (My computer->Properties->System protection->->Configure->check dot TURN OFF SYSTEM PROTECTION ) using regedit tool? I need this by the registry to I can put in automated process because we made about 4000 machines per day. Thanks in advance.
Performance & Maintenance
Need to turn on System Protection
I am trying to do a system restore. When I get to the screen titled 'confirm disks to restore' it says 'you must enable System Protection on this drive'. I am unable to enable System Protection thru normal means because the tab isn't showing up. I searched the forum and found an answer in the...
