Windows 7: System Protection - Turn On or Off
How to Turn System Protection On or Off in Windows 7
Published by Brink
04 Nov 2008
information   Information
System Restore regularly tracks changes to your computer's system files, and uses a feature called System Protection to create restore points of selected hard disks in your computer. System Protection is turned on by default for the Windows 7 hard disk or partition on your computer.
This will show you how to turn System Protection On or Off for creating System Restore Points for system settings and previous versions (shadow copies) of files in Windows 7. You could also use previous versions (shadow copies) to restore older copies of files and folders.
You can select which disks have System Protection turned on for.
Note   Note
It is not recommended to turn off system protection for your C: system drive (Windows 7) since it is a great tool to easily undo a mistake, for example one that may have crippled Windows 7, by just doing a system restore to go back to a previous restore point of your system dated before the mistake.
warning   Warning
  • System Restore doesn't protect FAT32 and other FAT disks because FAT disks don't support the use of shadow copies. Shadow copies contain information about changes to documents and system files. Shadow copies require the NTFS file system. Windows 7 uses the NTFS file system.
  • Turning off System Protection for a disk deletes all restore points for that disk. You cannot restore the disk until you turn on System Protection again and a restore point is created for that disk.
Here's How:
1. Open the Control Panel (Icons View).
A) Click on the System icon.
B) Go to step 3.
OR
2. Open the Start Menu.
A) Right click on the Computer button and click on Properties.
3. Click on the System Protection link. (see screenshot below)
4. If prompted by UAC, then click on Yes if administrator or type in the adminstrator's password if standard user.
5. Click on the available hard disk drive or partition, that you want to turn System Protection on or off for, to select it. (see screenshot below step 6)
NOTE: Windows 7 should be the C: drive with (System). Under the Protection column, you will see if System Protection is turned On or Off for the available disk.
6. Click on the Configure button. (see screenshot below)
7. To Turn On System Protection for System Settings and Previous Versions of Files
A) Dot Restore system settings and previous versions of files. (see screenshot below step 10)
NOTE: This turns on creating restore points and Previous Versions for the selected drive in step 5.
B) Move the Max Usage slider to set the maximum disk space usage you want to be used by system protection on the selected drive letter.
C) Go to step 10.
8. To Turn On System Protection for Only Previous Versions of Files
A) Dot Only restore previous versions of files. (see screenshot below step 10)
NOTE: This turns on only Previous Versions for the selected drive in step 5.
C) Go to step 10.
9. To Turn Off System Protection for the Selected Disk
A) Dot Turn off system protection. (see screenshot below step 10)
NOTE: This turns off both creating restore points and Previous Versions for the selected drive in step 5.
B) Go to step 10.
10. Click on OK. (see screenshot below)
11. Repeat steps 5 to 10 if you wanted to turn System Protection on or off for another listed drive.
12. When finished, click on OK. (see screenshot below step 6)
24 Oct 2009   #1
adgower
windows 7 pro 64 bit
Worked perfectly! Thanks!
04 Nov 2009   #2
shortmantuff
Windows 7 Home Premium x86
Anyway to turn off System Restores at boot or shutdown?
04 Nov 2009   #3
Brink
64-bit Windows 10 Pro
Hello Shortmantuff,
Yes, you can disabled the startup task in Task Scheduler for this. There is not one for shut down though.
System Restore Task - Change Automatic Restore Point Schedule - Vista Forums
05 Nov 2009   #4
shortmantuff
Thanks Shawn!
05 Nov 2009   #5
Brink
You're welcome.
09 Dec 2009   #6
PETStech
Missing System Protection Tab on System Properties
I've just installed Windows 7 Home Premium and want to create restore points as I install apps.
The problem: there are only four tabs on System Properties and the System Protection tab is missing!
I checked Volume Shadowing service; it was off, so I set it to automatically start and then re-booted, but still no Protection tab.
I have plenty of space on the C: partition, although when I first did the install I had a smaller partition, which I subsequently enlarged to 400gb.
- Tom
09 Dec 2009   #7
Brink
Hello Tom, and welcome to Seven Forums.
You may have had something go wrong during installation. Was this a clean or upgrade install that you did? You might consider doing a clean (format) install instead or again to see if it is there afterwards.
10 Dec 2009   #8
PETStech
Missing System Protection Tab after 'clean' install
Shawn,
Thanks for your reply.
I did a 'clean install' which seemed to go without a hitch, and I have already installed 32 apps and performed additional organization and configuration of the new system. Doing another 'clean install' would be very 'distasteful' and a repeat of more than a day's work (I do not do these things, hastily). I was using a 3-pak installation disk. Might it have a different 'build' with things missing? I understand that in some builds, some essentail drivers had not been included, causing installation headaches.
So, if it is true that a new restore point is created after each exit/reboot, perhaps I'll forgo the luxury of setting the restore point, manually, and just reboot whenever I want to set a new one. Of course, I'd lose the labeling feature of a manually set restore point.
Whadaya think?
- Tom
10 Dec 2009   #9
Brink
Tom,
Normally a restore point will be created at each startup if a change to the system has been detected since the last restore point that was made. However, since you are misssing the "System Protection" tab, System Protection may not be enabled to have any restore points.
See if running a sfc /scannow command, then restart the computer afterwards may be able to restore it.
Windows Defender Real-Time Protection - Turn On or Off
How to Turn Windows Defender Real-Time Protection On or Off in Windows 7 Windows Defender real-time spyware protection runs in the background and alerts you when spyware and other potentially unwanted software attempts to install itself or run on your computer. This will show you how to...
Tutorials
Wordpad: how to turn off hyperlink protection question
Hello Maybe not the proper forum to ask, but I have no other clue where look for Using Wordpad, how can I remove the protection question: everytime I click on an hyperlink? Martin
General Discussion
Can I turn on system protection thru cmd? Windows is frozen.
I think that I have some "corrupt files" that were deleted after some auto updates were installed. This has created chaos in my windows. Normal mode windows locks up when booted, and now it is doing the same thing in safe mode. The only response I can get is in command. I also tried...
General Discussion
System Protection will not turn on
I recently had a power outage while Windows 7 (x64) was loading. System booted up fine. I went to do a system restore, but could not. When I go to select a restore point is says, "System Protection is turned off". I never turned it off and it will not let me turn it on. The C:\ clearly shows...
General Discussion
How to Turn Off System Protection by registry (regedit)
Is there any way to disable System Protection (My computer->Properties->System protection->->Configure->check dot TURN OFF SYSTEM PROTECTION ) using regedit tool? I need this by the registry to I can put in automated process because we made about 4000 machines per day. Thanks in advance.
Performance & Maintenance
Need to turn on System Protection
I am trying to do a system restore. When I get to the screen titled 'confirm disks to restore' it says 'you must enable System Protection on this drive'. I am unable to enable System Protection thru normal means because the tab isn't showing up. I searched the forum and found an answer in the...
