Windows 7: Graphics Card Problems - Diagnose
09 May 2014   #10
essenbe
Windows 7 Enterprise X64/Windows 10 Enterprise X64/Windows 10 Pro X64/Linux Mint
You should be able to look at it and see just before it crashes, something changes dramatically. That should tell you where to look. Was it a voltage drop? That would normally indicate the PSU. If it was the graphics core clock drop it would indicate either a driver crash or the card itself malfunctioning. I would think a driver crash would show several things drop at the same time. If only one thing drops it should indicate the card. But, hopefully it should show where you need to look for the problem.
09 May 2014   #11
paulpicks21
Windows 7 Professional 64 bit
Ok thanks Steve, hopefully I will not need to use it but at least I know what to look out for now if I do.
11 May 2014   #12
Dude
Windows 10 Pro X64
Great job Steve. Bookmarked
11 May 2014   #13
essenbe
Thanks Doug.
18 May 2014   #14
andrew129260
Windows 10 Pro
Great job!
May I make a suggestion?
Put this quote in the tutorial last step:
Quote   Quote: Originally Posted by essenbe View Post
08 Oct 2014   #15
sharpnova
This isn't very helpful. If you are trying to diagnose an issue that may be gpu related that is crashing your computer, then this won't finish its test due to a very subtle issue. It's subtle enough that I can't blame you for not realizing it when you made this post:
In order for the test to finish and log results and give you information that might be useful it has to be able to run up until the point of usefulness.
This is where it gets tricky. In order for it to run, it needs to be being executed in some way. It could be in the thoughts of some god or on what we call a computer.
For our purposes let's say we're running it on our computer. Let's call this computer X. Now let's say our issue involves X crashing.
At the point of the crash, X will no longer be able to facilitate the function of this diagnostic utility.
But we already stated that this utility needs to be facilitated by something which runs it in order for it to demonstrate its utility.
So we have proven, by contradiction (a useful mathematical tool) that this tool cannot be useful.
At least not in the case where you are trying to use it to diagnose a problem with your video card that is causing a crash.
Did you have some other use in mind?
14 Nov 2014   #16
mjf
Windows 7x64 Home Premium SP1
Thanks.
I saw a strange graphics hardware error message in my event log on my GTS450. I'll follow the instructions. I'm not into gaming so this stuff is a little foreign to me.
New graphics card having problems
So I recently built my first computer. I don't understand most things I just followed a tutorial I'm not going to lie. So my graphics card was late arriving, so I tried to use the video card settings or whatever on the motherboard, just to install stuff first you know, but I always got a 'your...
Graphic Cards
new graphics card problems
Hi. I have a medeon pc. spec are : Windows 7 Home Premium Service Pack 1 (build 7601) Install Language: English (United States) System Locale: English (United Kingdom) Installed: 17/11/2009 09:47:14 MEDIONPC MS-7366 2.2 Enclosure Type: Desktop
Graphic Cards
WIFI and Graphics Card Problems!!
Hi there, i am having probs with my Windows 7 i believe, its genuine and up to date. From time to time my wifi cuts out and my pc says limited/no connectivity, when other computers are online fine. Also when i leave my pc for 5 mins or more, when the computer goes into standby mode, it blue...
Hardware & Devices
AGP GRAPHICS CARD PROBLEMS... help please
Ok. im no noob. i build computers on the side and know a fair bit about them. i have tones of nice boards like 2,8 intels or better that use agp graphics. i try to put one of the 20 agp card i have lying around in (nice cards)... geforce 128 and 256's and windows 7 dose not recognize any of them...
Graphic Cards
2 Problems after upgrading graphics card
My new Graphics card: Galaxy 250 GTS 512MB Overclocking? No, not atm. Tested and happens under-clocked and super-clocked MY MONITOR: HP 2009m Latest drivers: Yes! For both graphics card and Motherboard! PROBLEMS: 1. When I play games, the screen sorta has flickering, dull lines on it. SUPER...
Graphic Cards
Having problems with graphics card in windows 7 help
hey guys please help ive installed windows 7 in c drive i deleted the hard drive first before i installed it. now my mouse keeps freezing every so often but when i press a button it refreshes for a few seconds before freezing again ive updated as much as i can i put in a old graphics card and...
Graphic Cards
