ClearType Text Tuner
Page 2 of 2 FirstFirst 12
  1. Posts : 72,055
    Hello Chrysalis,
    After you uncheck the box to turn off ClearType, see if restarting the computer afterwards may help.
  2. Posts : 529
    windows 8.1 Pro x64
    makes no difference but after changing the font type in the advanced appearance options I have removed nearly all cleartype, also set cleartype gamma to 0 in the registry.
  3. Posts : 72,055
       #12
    Chrysalis,
    I'm happy to hear that you got it sorted. Thank you for posting back your results. :)
  4. Posts : 529
    windows 8.1 Pro x64
    yep, I will eventually probably at least turn some cleartype back on, this is been done on this machine whilst I investigate 2d performance issues on this machine.
  5. Xap
    Win7 Ultimate 32b
       #14
    I need smooth edges but NO cleartype. I use ClearType Switch to disable it but I still get blurry text on windows' titles and some other controls. How do I turn it off completely?
    See attachment below.
  6. Posts : 72,055
       #15
    Hello Xap,
    I'm afraid that's what ClearType is for. That's what your going to get without it. You might see if changing the default font in Windows using OPTION THREE in the tutorial below to one that looks better may help.
    Fonts - Change
    Hope this helps. :)
  7. Xap
    Win7 Ultimate 32b
       #16
    No, it is not. There is separate option for edge smoothing that works without cleartype.
    I've already changed all my fonts to Tahoma (as you can see on menu @ the screenshot) but I still get cleartype on some controls.
    UPDATE: Ok, I've fixed almost all my fonts to Tahoma with no cleartype by modifying aero.msstyles. But windows' caption are still blurry because of cleartype. It seems like Windows totally ignores CAPTIONFONT:FONT parameter in *.msstyles.
