Repair Install
How to Do a Repair Install to Fix Windows 7
This will show you how to do a repair install (aka: in-place upgrade install) to fix your currently installed Windows 7 and preserve your user accounts, data, programs, and system drivers.
Do a Repair installation if:
  • A System Restore did not help fix your Windows 7.
  • There is no other easier option left that can fix your Windows 7.
  • You DO NOT want to do a Clean reinstall of Windows 7.
  • You DO want to preserve your user accounts, data, programs, and system drivers.
   Tip
ITEMS THAT WILL BE RESET TO DEFAULT OR AFFECTED:
  • Sounds
  • Services
  • Visual Effects Settings
  • Device Drivers - Be sure to have these handy to reinstall. They do not always remain after the repair (upgrade) install.
  • You may lose the ability to sign on to MSN Messenger, to solve this problem have a look at this thread Unable to sign in to WLM.
  • You may lose your custom themes due to not having permisions set on the old themes. Go to the hidden themes folder at C:/Users/(User-Name)/AppData/Local/Microsoft/Windows/Themes, then Take Ownership of the themes folder and you will now have all your themes back.
  • It has been reported that you may also lose your Media Center gadget after doing the repair install.
  • Windows Updates will need to be checked and reinstalled again.
   Warning
  • You can only do a repair install with the same edition Windows 7 installation disc for the same edition of Windows 7 that you have installed.
  • You cannot use a OEM Windows 7 "Factory" Restore/Recovery type of installation disc that came with or created from a store bought computer to do a repair install with. These can only be used do a clean install instead.
  • You can do a repair install on a factory OEM installation with the latest official Windows 7 with SP1 ISO file here: Microsoft: Windows 7 Direct Download Links, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7.
  • You can use a retail OEM Windows 7 installation disc to do a repair install with.
  • You can use a retail (full or upgrade) Windows 7 installation disc to do a repair install with.
  • You cannot do a repair install with a System Repair Disc. A System Repair Disc is not a installation disc, and will only boot to the System Recovery Options screen.
  • If you have a 32-bit (x86) Windows 7 currently installed, then you must use a 32-bit Windows 7 installation disc to be able to do a repair install with.
  • If you have a 64-bit (x64) Windows 7 currently installed, then you must use a 64-bit Windows 7 installation disc to be able to do a repair install with.
  • You can use a retail Windows 7 SP1 installation disc (ex: Technet (available), MSDN (available), or retail (when available)) to do a repair install with on a currently installed Windows 7 SP1.
  • You can use a Windows 7 SP1 installation disc (ex: Technet (available), MSDN (available), or retail (when available)) to do a repair install with on a currently installed slipstream Windows 7 SP1.
  • You cannot use a slipstream Windows 7 installation disc to do a repair install with on a currently installed Windows 7 SP1.
  • You cannot use a slipstream Windows 7 installation disc to do a repair install with on a currently installed slipstream Windows 7 SP1.
  • You can only do a repair install from within Windows 7.
  • You cannot do a repair install at boot or in Safe Mode.
  • You must be logged into Windows 7 in a administrator account to be able to do a repair install.
  • You must have at least 8.87 GB + what is currently being used of free space (more if you have a larger installation) on the hard drive/partition Windows 7 is installed on to do a repair install.
  • If you changed the default location of a user account's profile folder, then you will need to change it back to the default C:\Users location first.
  • If you moved the default location of a user folder, then you will need to change it back to the default C:\Users\(user-name) location first.
Here's How:
NOTE: Be sure to back up anything that you do not want to lose first to be extra safe.1. Start Windows 7, and log on to an administrator account.
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the repair in-place upgrade installation of Windows 7.
3. Do either step 4, step 5, or step 6 below depending if your retail Windows 7 installation ISO/DVD/USB has SP1 or not, and if your currently installed Windows 7 has SP1 installed or not.
4. Repair Installed Windows 7 SP1 using Windows 7 with SP1 ISO
If you do not have a Windows 7 with SP1 ISO, then you can download an official ISO with your retail product key from Microsoft at the link below.
:ar: Microsoft Software Recovery
You can also download the latest official Windows 7 SP1 Media Refresh (SP1 U) ISO file at the link below, but this link is not always available for download.
:ar: Microsoft: Windows 7 Direct Download Links
A) If you have not already, you will need to install a program like 7-Zip that supports extracting a ISO to a folder.
B) Using the program (ex: 7-Zip) from step 1, extract the Windows 7 SP1 ISO file to a folder on a partition or HDD other than the current Windows 7 partition. (see screenshot below)
NOTE: For example with 7-Zip, right click on ISO, click on 7-Zip, Extract files, browse button, select where you want to extract to, and click on OK twice.7-Zip.jpg
C) While in Windows 7 SP1, open the folder that you extracted the ISO into, and run the setup.exe file.
D) Go to step 7 below.
5. Repair Installed Windows 7 SP1 using Windows 7 with SP1 DVD/USB
:ar: http://www.microsoft.com/en-us/software-recovery
Afterwards, you can use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7 using this step.
A) While in Windows 7 SP1, insert your retail Windows 7 SP1 installation DVD into the DVD drive, or connect your Windows 7 with SP1 installation USB thumb drive, and click on the Run setup.exe option in AutoPlay. (see screenshot below)
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.AutoPlay.jpg
B) Go to Go to step 7 below.
6. Repair Installed Windows 7 without SP1 using Windows 7 without SP1 DVD/USB
If you do not have a Windows 7 without SP1 installation DVD/USB, then you can download the latest official Windows 7 Professional or Home Premium without SP1 ISO file here: Microsoft: Windows 7 Direct Download Links, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7 using this step.
It is preferred to have SP1 installed on your PC and to use step 4 or step 5 above to do a repair install with instead though.
A) While in Windows 7 SP1 installed, insert your retail Windows 7 installation DVD into the DVD drive, or connect your Windows 7 installation USB thumb drive, and click on the Run setup.exe option in AutoPlay. (see screenshot below)
7. If prompted by UAC, then click on Yes.
8. Click on the Install Now button to start the installation. (see screenshot below)Step1.jpg
9. If prompted, uncheck the I want to help make Windows installation better box (unless you would like to :) ), and click on the Go online to get the latest updates for installation option. (see screenshot below)Step2.jpg
A) Windows 7 will now check online for and install any available installation updates. (see screenshots below)Step2A.jpg
10. Check the I accept the license terms box, and click on Next. (see screenshot below)Step3.jpg
12. Windows will now check for any compatibility issues. If any are found like in the example below, click on the red X to cancel the repair install and close this "Install Windows" window, take care of any found issues (ex: uninstall any incompatible program), then restart the repair install process over again.Compatibility-Report.jpg
13. The installation of Windows 7 will now begin. (see screenshot below)
NOTE: During the installation process, your screen may flash and computer will restart a few times.Step5.jpg
14. After the final restart, you will see this screen for a moment. (see screenshot below)Step6.jpg
15. Type in your Windows 7 product key number. (see screenshot below step 16)
16. Uncheck the Automatically activate Windows when I'm online box unchecked, then click on the Next button. (see screenshot below)
NOTE: You can activate Windows 7 later after you make sure it is running properly. (see step 23 below)
If you chose to automatically activate Windows online when you set up your computer, automatic activation begins trying to activate your copy of Windows three days after you log on for the first time.Step7.jpg
17. Click on Use recommended settings. (see screenshot below)
:note: You will always be able to change your Windows Update settings at anytime in Windows 7.
18. Select your time zone and set your time and date settings, then click on the Next button. (see screenshot below)Step9.jpg
19. Click on the option for your computer's location to select the correct network location type settings to be applied for that location. (see screenshot below)
NOTE: It is best to select Public location for the best security.Step10.jpg
20. Windows 7 will now prepare your desktop to startup. (see screenshots below)Step11A.jpg
21. If you used a DVD or USB to do the repair install with, then you can remove the DVD or USB when the repair install has successfully completed and you are logged in to Windows 7.
22. Check to see if you are missing any user files. If you are, then you can copy them from the C:\Windows.old or the hidden protected operating system C:\$INPLACE.~TR and C:\WINDOWS.~Q backup folders. (see screenshot below)Old_Install.jpg
23. If everything checks out in step 21, then you can run Disk Cleanup (step 5 at this link). You will need to click on the Clean up system files button first, and then could check the Files discarded by Windows upgrade, Previous Windows installations, and Windows upgrade log files boxes. (see screenshot below)
NOTE: This will delete the C:\Windows.old, C:\$INPLACE.~TR and C:\WINDOWS.~Q folders from step 21 above.Disk_Cleanup.jpg
24. Refresh your Windows Experience Index (WEI) score.
25. When finished, activate Windows 7, and make sure that your 3rd party security programs (if applicable) are enabled again.
Hello vtails, and welcome to Ten Forums. :)
I'm not 100% sure what "numbers" it's asking for, but you do not get asked for a product key to download a Windows 10 ISO file.
Windows 10 ISO Download - Windows 10 Forums
Sorry about the miss info it was the download link for Windows 7 on the first page of the Thread, it has the numbers section and then the verify tab, I'm not sure why they would do this just to D/L Win 7. I didn't want to have them apply the number's to this computer, I am not sure I know enough to fix all the issue's as I keep finding more problems as I go.I have done 2 clean installs and each has had issue's, I have changed the H/D and Memory it hasn't changed anything. I've used this disk on a few computer's over the years and not had trouble at all. It was an XP before and also had Snow Leopard on it a while back, I think my grandkids are just going to have to be patient , I think I should have a laptop so I could look for solutions while working on a problem. Thank you for reading my problems.
Windows 7 Home Preminiun x64 Windows 10 home x64Turion Dual core TL-684 gig's DDR2 6400ATI 1150
Dell Inspiron
AMD UNKNOW MAKER
4 gig's DDR2 6400
ATI 1150
300 gig's
F-SECURE
IE 11
Ah, ok.
The product key is only used to verify ownership to download the ISO. It doesn't affect activation. :)
That's what I wanted to know, I didn't want to burn the key on this till I know if I can fix it. I've fixed some issue's so far and I think it will do for the grandkids a while. It be great have a Program That would just fix all issue's and be done but it does give me something to do at the Hanger while I take a break. Thank you for the info.
Dell Inspiron
AMD UNKNOW MAKER
4 gig's DDR2 6400
ATI 1150
300 gig's
F-SECURE
IE 11
You're welcome. I hope you get it sorted.
A once system-saving site now totally obsolete.
Microsoft links that supposedly provide access to Win7 iso files are presently available only in French and Korean languages. I am forced to assume that MS aggressive promotion of windows 10 now extends to blocking efforts to repair Win7.
Win7 AND WinXPP44GB (3.7 avail)Quadro FX540 128 GB
Win7 AND WinXP
P4
4GB (3.7 avail)
Quadro FX540 128 GB
Intel onboard
IBM C220 (CRT)
150GB WD Raptor (OSs), Seagate 320GB (Data etc), Seagate 500GB External (eSATA)
Yep, one has to resort to other sources to find a reliable Windows 7 ISO these days.
It's been a few years since I did a repair/install on my Win7 machine. Now I need to do so for my wife's Win7. After reading your instructions, I'm unclear on a few points and need to clarify before proceeding.
1. The Lenovo OEM OS key is located on a label on the machine's exterior. You say "The product key is only used to verify ownership to download the ISO. It doesn't affect activation". If that's the case then what do I (the machine) need for the activation process?
2. Under Computer/Properties, at the bottom is Product ID. This is not the key but is it necessary for the process (I think this is the identifier that Jelly Bean extracts).
3. Is it likely to initiate and substantially complete the process only for MS to say no at the end and you're left restoring the OS from a previously backed up image? If so, is there a way to get the end answer at the beginning ;-)
4. If I can find a MS ISO Professional 64 bit SP1, is there any way of consolidating/shortening the time involved to download and install the zillion updates post SP1?
Windows 7 & Windows 10
Hello Mark, :)
Q1) You would need the product key on the COA sticker to be able to activate Windows 7.
Q2) The identifier would be needed if you had to activate by phone.
Q3) There's always a chance the repair install could fail at the end, but it will usually always automatically revert back to where you started unless interrupted.
Q4) Getting the latest ISO version helps some, but there are still a ton of updates that will be available even with the latest ISO.
I found this site, it's a German mirror of all the ISOs.
http://mirror.corenoc.de/digitalrivercontent.net/
Windows 7 Home Premium x64Intel i7 950 @ 3.0712 GB
Acer Aspire G7750
Intel i7 950 @ 3.07
12 GB
Norton 360 Premier
Email notification problem(?)
I received notification of a new thread post 3/28/16. Here's the link: http://www.sevenforums.com/tutorials/3413-repair-install-new-post.html.
and the contents:
Here is the message that has just been posted:
[URL]http://mirror.corenoc.de/digitalrivercontent.net/
The link takes me to Brink's last post. I confirmed the target was the last post since '>' didn't move any further. I searched the page for both 'German' and 'abishaij1' with zero hits?
While I'm here I may as well ask my three questions about the post's content:
1. Are the ISO's in German or English?
2. Has anyone verified the integrity of the mirror site?
3. Is the site superior to that which the tutorial suggests?
Mark
[/URL]
Hello Mark, :)
Q1) The ISOs listed with "EN" in front of their names are the English versions.
Q2) I've never downloaded anything from them, so I can't verify how safe they are. I can verify the links in the tutorial are safe and official ISO files.
Q3) Unknown.
I just now made an account because I originally was going to ask what other places you can go since the sites in the tutorial both don't give the ISOs anymore, but then I read the last page and saw no one else seemed to know either. I can't confirm that they're safe as I haven't tried them yet; when i went to make a partition I found that the manufacturer had a recovery partition already and did the built in recovery. Now I'm getting a "Windows could not complete the installation. To install Windows on this computer, restart the installation." loop. Now I have to download it on my tablet since the fix seems to be a recovery disk, ironic that the recovery ****ed me into needing a recovery even more than I did before.
Acer Aspire G7750
Intel i7 950 @ 3.07
12 GB
Norton 360 Premier
It is good to always have reliable installation media. :(
This version of d:\boot\bootsect.exe is not compatible with the version of Windows you're running. Check your computer's system information and then contact the software publisher.
trying to fix my desktop which runs off of win7x64 right now im on a tablet/laptop which is running win8x86. what should i do to get this usb bootable?
Acer Aspire G7750
Intel i7 950 @ 3.07
12 GB
Norton 360 Premier
Using OPTION TWO below to create a boot Windows 7 installation USB works great. :)
http://www.sevenforums.com/tutorials/2432-usb-windows-7-installation-key-drive-create.html
To upgrade, you need to be running Windows 7 with service pack 1 installed. Close the installation, open windows update and then check updates for service pack 1.
I only even got that far by using shift f10 to open cmd and run the setup once I got to the
Windows can't install
Part... Am I ****ed? I have alot of data I really can't afford to lose.
Acer Aspire G7750
Intel i7 950 @ 3.07
12 GB
Norton 360 Premier
I've just performed a repair install (sp1), and am now in the Update loop...
MS update says it has never been performed. That makes sense based on doing the repair install. However, it is stuck in the "checking for updates..." loop for about 3 hours. Is that normal???
Thanks,
Ken
Microsoft Windows 7 Home Premium 64-bit 7601 ...AMD FX(tm)-8350 Eight-Core Processor16.00 GBNVIDIA GeForce GTX 670
Custom build
ASUSTeK Computer INC. M5A88-M
16.00 GB
(1) Realtek High Definition Audio (2) NVIDIA Virtual Audio
Through AVR to one of two TV/Projector
Samsung SSD 850 PRO 256G SATA Disk Device
Silverstone GD09
Air
Kaspersky Internet Security, 2015
Hello Ken, :)
It can sometimes take a long time to finish a repair install. Especially if you had many issues before.
If you still have hard drive activity indicating that it's still working on something, then it's best to let it sit until finished.
If it's not doing anything, then you could perform a hard shutdown and restart the PC to hopefully have it pick up where it left off. Doing this can risk the repair install failing and reverting back to where you were prior though.
I'm not at all sure that I am posting in the right place. I have several questions concerning details of doing a Repair Install of Windows 7. However, I note that the last post in this thread was in 2008, so I won't ask my questions until I know I'm in the right place. Assuming that this is NOT the correct place to ask questions and seek clarification on this issue, I hope someone can point me to where I need to be. Thanks for any assistance.
Windows 7 Ultimate 64Intel i7-97512 GBATI Radeon HD 5870
Intel i7-975
12 GB
ATI Radeon HD 5870
Sound Blaster X-Fi Titanium
Dell U2410
3, SATA 1.5 TB each
