Repair Install
How to Do a Repair Install to Fix Windows 7
This will show you how to do a repair install (aka: in-place upgrade install) to fix your currently installed Windows 7 and preserve your user accounts, data, programs, and system drivers.
Do a Repair installation if:
  • A System Restore did not help fix your Windows 7.
  • There is no other easier option left that can fix your Windows 7.
  • You DO NOT want to do a Clean reinstall of Windows 7.
  • You DO want to preserve your user accounts, data, programs, and system drivers.
   Tip
ITEMS THAT WILL BE RESET TO DEFAULT OR AFFECTED:
  • Sounds
  • Services
  • Visual Effects Settings
  • Device Drivers - Be sure to have these handy to reinstall. They do not always remain after the repair (upgrade) install.
  • You may lose the ability to sign on to MSN Messenger, to solve this problem have a look at this thread Unable to sign in to WLM.
  • You may lose your custom themes due to not having permisions set on the old themes. Go to the hidden themes folder at C:/Users/(User-Name)/AppData/Local/Microsoft/Windows/Themes, then Take Ownership of the themes folder and you will now have all your themes back.
  • It has been reported that you may also lose your Media Center gadget after doing the repair install.
  • Windows Updates will need to be checked and reinstalled again.
   Warning
  • You can only do a repair install with the same edition Windows 7 installation disc for the same edition of Windows 7 that you have installed.
  • You cannot use a OEM Windows 7 "Factory" Restore/Recovery type of installation disc that came with or created from a store bought computer to do a repair install with. These can only be used do a clean install instead.
  • You can do a repair install on a factory OEM installation with the latest official Windows 7 with SP1 ISO file here: Microsoft: Windows 7 Direct Download Links, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7.
  • You can use a retail OEM Windows 7 installation disc to do a repair install with.
  • You can use a retail (full or upgrade) Windows 7 installation disc to do a repair install with.
  • You cannot do a repair install with a System Repair Disc. A System Repair Disc is not a installation disc, and will only boot to the System Recovery Options screen.
  • If you have a 32-bit (x86) Windows 7 currently installed, then you must use a 32-bit Windows 7 installation disc to be able to do a repair install with.
  • If you have a 64-bit (x64) Windows 7 currently installed, then you must use a 64-bit Windows 7 installation disc to be able to do a repair install with.
  • You can use a retail Windows 7 SP1 installation disc (ex: Technet (available), MSDN (available), or retail (when available)) to do a repair install with on a currently installed Windows 7 SP1.
  • You can use a Windows 7 SP1 installation disc (ex: Technet (available), MSDN (available), or retail (when available)) to do a repair install with on a currently installed slipstream Windows 7 SP1.
  • You cannot use a slipstream Windows 7 installation disc to do a repair install with on a currently installed Windows 7 SP1.
  • You cannot use a slipstream Windows 7 installation disc to do a repair install with on a currently installed slipstream Windows 7 SP1.
  • You can only do a repair install from within Windows 7.
  • You cannot do a repair install at boot or in Safe Mode.
  • You must be logged into Windows 7 in a administrator account to be able to do a repair install.
  • You must have at least 8.87 GB + what is currently being used of free space (more if you have a larger installation) on the hard drive/partition Windows 7 is installed on to do a repair install.
  • If you changed the default location of a user account's profile folder, then you will need to change it back to the default C:\Users location first.
  • If you moved the default location of a user folder, then you will need to change it back to the default C:\Users\(user-name) location first.
Here's How:
NOTE: Be sure to back up anything that you do not want to lose first to be extra safe.1. Start Windows 7, and log on to an administrator account.
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the repair in-place upgrade installation of Windows 7.
3. Do either step 4, step 5, or step 6 below depending if your retail Windows 7 installation ISO/DVD/USB has SP1 or not, and if your currently installed Windows 7 has SP1 installed or not.
4. Repair Installed Windows 7 SP1 using Windows 7 with SP1 ISO
If you do not have a Windows 7 with SP1 ISO, then you can download an official ISO with your retail product key from Microsoft at the link below.
:ar: Microsoft Software Recovery
You can also download the latest official Windows 7 SP1 Media Refresh (SP1 U) ISO file at the link below, but this link is not always available for download.
:ar: Microsoft: Windows 7 Direct Download Links
A) If you have not already, you will need to install a program like 7-Zip that supports extracting a ISO to a folder.
B) Using the program (ex: 7-Zip) from step 1, extract the Windows 7 SP1 ISO file to a folder on a partition or HDD other than the current Windows 7 partition. (see screenshot below)
NOTE: For example with 7-Zip, right click on ISO, click on 7-Zip, Extract files, browse button, select where you want to extract to, and click on OK twice.7-Zip.jpg
C) While in Windows 7 SP1, open the folder that you extracted the ISO into, and run the setup.exe file.
D) Go to step 7 below.
5. Repair Installed Windows 7 SP1 using Windows 7 with SP1 DVD/USB
:ar: http://www.microsoft.com/en-us/software-recovery
Afterwards, you can use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7 using this step.
A) While in Windows 7 SP1, insert your retail Windows 7 SP1 installation DVD into the DVD drive, or connect your Windows 7 with SP1 installation USB thumb drive, and click on the Run setup.exe option in AutoPlay. (see screenshot below)
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.AutoPlay.jpg
B) Go to Go to step 7 below.
6. Repair Installed Windows 7 without SP1 using Windows 7 without SP1 DVD/USB
If you do not have a Windows 7 without SP1 installation DVD/USB, then you can download the latest official Windows 7 Professional or Home Premium without SP1 ISO file here: Microsoft: Windows 7 Direct Download Links, and use Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7 using this step.
It is preferred to have SP1 installed on your PC and to use step 4 or step 5 above to do a repair install with instead though.
A) While in Windows 7 SP1 installed, insert your retail Windows 7 installation DVD into the DVD drive, or connect your Windows 7 installation USB thumb drive, and click on the Run setup.exe option in AutoPlay. (see screenshot below)
7. If prompted by UAC, then click on Yes.
8. Click on the Install Now button to start the installation. (see screenshot below)Step1.jpg
9. If prompted, uncheck the I want to help make Windows installation better box (unless you would like to :) ), and click on the Go online to get the latest updates for installation option. (see screenshot below)Step2.jpg
A) Windows 7 will now check online for and install any available installation updates. (see screenshots below)Step2A.jpg
10. Check the I accept the license terms box, and click on Next. (see screenshot below)Step3.jpg
12. Windows will now check for any compatibility issues. If any are found like in the example below, click on the red X to cancel the repair install and close this "Install Windows" window, take care of any found issues (ex: uninstall any incompatible program), then restart the repair install process over again.Compatibility-Report.jpg
13. The installation of Windows 7 will now begin. (see screenshot below)
NOTE: During the installation process, your screen may flash and computer will restart a few times.Step5.jpg
14. After the final restart, you will see this screen for a moment. (see screenshot below)Step6.jpg
15. Type in your Windows 7 product key number. (see screenshot below step 16)
16. Uncheck the Automatically activate Windows when I'm online box unchecked, then click on the Next button. (see screenshot below)
NOTE: You can activate Windows 7 later after you make sure it is running properly. (see step 23 below)
If you chose to automatically activate Windows online when you set up your computer, automatic activation begins trying to activate your copy of Windows three days after you log on for the first time.Step7.jpg
17. Click on Use recommended settings. (see screenshot below)
:note: You will always be able to change your Windows Update settings at anytime in Windows 7.
18. Select your time zone and set your time and date settings, then click on the Next button. (see screenshot below)Step9.jpg
19. Click on the option for your computer's location to select the correct network location type settings to be applied for that location. (see screenshot below)
NOTE: It is best to select Public location for the best security.Step10.jpg
20. Windows 7 will now prepare your desktop to startup. (see screenshots below)Step11A.jpg
21. If you used a DVD or USB to do the repair install with, then you can remove the DVD or USB when the repair install has successfully completed and you are logged in to Windows 7.
22. Check to see if you are missing any user files. If you are, then you can copy them from the C:\Windows.old or the hidden protected operating system C:\$INPLACE.~TR and C:\WINDOWS.~Q backup folders. (see screenshot below)Old_Install.jpg
23. If everything checks out in step 21, then you can run Disk Cleanup (step 5 at this link). You will need to click on the Clean up system files button first, and then could check the Files discarded by Windows upgrade, Previous Windows installations, and Windows upgrade log files boxes. (see screenshot below)
NOTE: This will delete the C:\Windows.old, C:\$INPLACE.~TR and C:\WINDOWS.~Q folders from step 21 above.Disk_Cleanup.jpg
24. Refresh your Windows Experience Index (WEI) score.
25. When finished, activate Windows 7, and make sure that your 3rd party security programs (if applicable) are enabled again.
you're a life saver
i registered just to be able to thank you. Brink my man, you're a life saver!
had this weird problem with fonts, for some reason everything was itallic in ie8 and i tried everything i cud think of.
was goin to reinstall when i found this guide.
totally fixed the problem. and, i'm happy to report that my Live Messenger was not hurt during this operation. :D
Win7 of course
Win7 of course
You're welcome Haplo, and welcome to Seven Forums. Thank you for posting your results. :)
Can't boot
This tutorial assumes you can boot into Windows 7, but what if you can't?
My system was all set up and running perfectly (better than it ever did XP).
Then I decided to try out WarCraft 3 again. It installed and played fine, but when I exited the program, all Aero features were disabled and the options to turn them back on in Control Panel were greyed out. So I tried to restart, but while shutting down I got the BSOD and now the system will no longer boot.
I tried system restore, to no effect. Then I tried the start up repair, but that only managed to make things worse (I can now no longer access the repair options during the boot process).
Is there any way to fix this without formatting?
Windows 7 RC1AMD Athlon 64 X2 Dual Core 4200+2GB OCZ DDR PC3200NVidia GeForce 8600 GT 256MB
PC MUTT
Windows 7 RC1
ASRock 939Dual SATA-2
2GB OCZ DDR PC3200
Creative Sound Blaster Audigy Gamer
LG Flatron W2242T 22-inch LCD widescreen
1600 x 1050
80GB IDE Seagate HDD -- Windows 7
80GB IDE Western Digital HDD -- Windows XP SP3
500GB Western Digital external HDD x2
Logitech Wireless Wave
High-speed cable
Hello Velvetman,
You might see if you can boot into Safe Mode to uninstall WarCraft 3 to see if that may help.
However, it does sound like you may need to do a clean install instead. :(
I laugh my ass off when i see this error
I swear I am on windows 7, need to do a repair install becos of some rtutils.dll error
any idea why setup says i am on window xp?
Hello Auggie, and welcome to Seven Forums.
What build of Windows 7 are you using? Did you make any modifications to it? For example, a watermark remover.
oh yea a watermark remover and nothing esle , and how do i check wat RC i am on
There is 1 thing you could try...
Run 'Command Prompt' as Administrator and type sfc /scannow.
This will scan and replace the files altred using the Watermark patch. Then you should be able to carry on with what you were doing.
Hope this helps :)
Jeff
Windows 7 Ultimate x64AMD Sempron Dual Core3GBNVIDIA GeForce 6150SE nForce 430
Compaq Desktop
3GB
1024x768
150GB Sata
oh yea i actually did that but erm the watermark is still not reappearing
EDIT:
Auggie,
Other than from the watermark, you can see what build number you have in About Windows.
See if you can run the repair install now that you ran the SFC /SCANNOW command. Those watermark removers can cause problems like this that usually end up in a clean reinstall to fix. :(
Erm i replied in the previous post the screenshot of sfc scannow
nothing happened
and i am on Version 6.1 RC 7100
Auggie, it looks like you may need to do a clean install to fix this then. :(
...clean install, no way
i am going back to my partition XP...
windows 7 is good but there are too much restrictions
Sorry to hear that one! auggie 7 walks right past XP and is an improvement over Vista still.
    W7 Ultimate x64/W10 Pro x64/W11 Pro Triple Bo...AMD Phenom II X4 975 Deneb 3.6ghz - 965 2nd r...Kingston Hyper X DDR3 1600 1.5v 16gb - Hyper ...MSI HD Radeon 5750 1gb - MSI HD Radeon 6450 o...
    Custom builds = 2
    Asus 1440x900 - HP 1600x900
    Zalman CNPS9900A
    W7 Pro x64/W11 ProAMD Deneb 3.6ghz - 965Kingston Hyper X Fury 8gbMSI HD Radeon 6450 DVI Output
    CUSTOM ASSEMBLY
    W7 Pro x64/W11 Pro
    1600x1080
    NZXT Vulcan mini tower
    DSL 5G
Auggie:
You can do a system restore (to an earlier saved restore point) from the installation disk.
I know because I just did one. Took me two hours to figure out how... but it works.
windows 7 x64 Home Premiumintel q6600g.skill 8gb ddr2 1066 (pc2 8500)evga geforce 9800 gtx 512 mb
me / #1
intel q6600
gigbyte ga ep45 ud3l
wd caviar black 500 gb
wd caviar black 1tb
wd elements 1tb external hd x2
raidmax 500w
smilodon (yes, t'was the pretty blue lites that got me!)
Repair windows7
i have followed the steps but every time ia pop window appear and it's says an error happened check the source of installation cant' remember exactly what was said and the re is this number 0xe00001000
Microsoft Windows 7 UltimateDualCore Intel Core 2 Duo E4500, 2200 MHz (11...1024 MB (DDR2-667 DDR2 SDRAM)NVIDIA GeForce 7300 GT (Prerelease - WDDM 1.0)
Microsoft Windows 7 Ultimate number 7100
DualCore Intel Core 2 Duo E4500, 2200 MHz (11 x 200
Abit Fatal1ty FP-IN9 SLI (2 PCI, 2 PCI-E x
Realtek ALC888/1200 @ nVIDIA nForce 430i (MCP5
acer 19 " wide
C: (NTFS) 80003 MB (23748 MB free)
Current Power Source AC Line
dunno what ur talking about
intel standard
Keyboard Name Clavier standard PS/2 genius
genius
1 Go
Hello Chuckybride, and welcome to Seven Forums.
Without all of the error messages it's hard to say, but you may have a bad installation DVD. See if creating a new one may work better for you instead.
Repair Install without logging in first
Hi ya'll, new here,
I have Windows 7 and only 7 installed on my Sager NP9662 (bought off ebay and only had 7, no Vista dual-boot).
Some problem arose when I tried to shut down my notebook and it wouldn't shut down. It stayed on the shut down screen for over 10 minutes when it normally shuts down within 10 seconds. I held down the power button and forced it to turn off. When I restarted, the notebook went to the boot options menu (Safe Mode, Last Known Good etc). I tried to start Windows normally and it loaded some, then crashed down to Windows Error Recovery, with the options Launch Startup Repair and Start Windows normally. I tried to Launch the Startup Repair and it says Loading Files on the bottom. After it loads, it crashes (and restarts automatically back to Windows Error Recovery).
The same problems happen when I try to Start Windows Normally.
So, I don't want to lose the data on the Sager, as in, I really really don't want to lose any data... at all, so now I'm stuck with no recovery options.
I've tried F8, Advanced Boot Options.... Last Known Good Config... I've tried the Restore Mode and that didn't load...
I've downloaded the Windows 7 Beta iso and burnt it to a DVD already. I tried to see if there was a repair option on the install, but it seems like it's only giving me the "clean install" option...
Any help?
Thanks, Tim
Windows 7P96004GBNVIDIA 260M
Sager NP8662
P9600
4GB
NVIDIA 260M
128GB SSD
Hi Tim, and welcome to Seven Forums.
Unfortunately, you can only do a repair install from within the running Windows 7 since it is a upgrade install. It cannot be done at boot.
You might see if doing a System Restore at boot using a restore point dated before you had this problem may help though.
Directory Services Restore Mode?
That doesn't load, it says "loading files" then restarts the computer (because it crashed)
Or are you talking about something else?
Sager NP8662
P9600
4GB
NVIDIA 260M
128GB SSD
