Repair Install
Page 39 of 218 FirstFirst ... 29373839404149139 ... LastLast
  1. Posts : 3
    Windows 7 Pro x64, Windows XP Pro x32
       #380
    Ohh... Because I can't boot into my windows 7 anymore, and I don't want to lose my files...
  2. Posts : 72,052
       #381
    No worries Mipset.
    You could do a custom install of Windows 7 instead. This is like a clean install except that it creates a C:\Windows.old folder during the custom installation that will contain a copy of your current installation in it as a backup. After the custom install is done, you can copy what you want from within the C:\Windows.old folder back into your new installation.
    You will still have to reinstall all of your programs and drivers though.
  3. Posts : 3
       #382
    Hi Brink,
    I have seen the Windows.old folder before, when I upgraded from my Ultimate Vista 32x to my current Win7Pro64x, however in that folder, it only retains the windows installation, but not any of my documents.
    Are you certain everything will be okay? I'm super nervous, I have many important documents I can't spare to lose.
    Regards,
    Mipset
  4. Posts : 72,052
       #383
    They have always been there for me in the C:\Windows.old folder when doing a custom install of Windows 7 from Windows 7.
  5. Posts : 242
    I only see three steps. How do I access the rest of them? Thanks.......
  6. Posts : 6,349
       #385
    Repair Install
    There are about 21 steps or so click the link or better yet click the First by the page numbers at top or bottom of right side of this page.
  7. Posts : 72,052
       #386
    Hello Nisko,
    There are 21 steps in the tutorial on the first page of this thread where the tutorial starts.
  8. Posts : 242
    Brink said:
    Hello Nisko,
    Sorry, but I don't see the other steps. In any case, I think my problem is that the font kalinga.ttf is corrupt. How can I get this font and what do I have to do to install it? Thank you.......
  9. Posts : 72,052
       #388
    Nisko,
    When you click on the link in the post above to go to the first page, be sure that you are scrolling down the page with your arrow keys to see the other steps.
    The font issue is a different topic than what this tutorial is for, so you would be best to post about that issue in a new thread instead for better help on it.
  10. Posts : 242
    Brink said:
    Hello Nisko,
    Thanks for the effort - but it didn't work. I;m going to have to re-read the log to see if I missed something.
