#610
Licence Type: OEM
Service Pack: SP1
Bit Version: 64
So what about those folders on the C drive can I deleted them? Since they don't show up on Disk Cleanup.
Licence Type: OEM
Service Pack: SP1
Bit Version: 64
Ok, it's a "retail" OEM copy, and not a factory recovery/restore OEM type then.
Sure, you can manually delete the files listed in step 18 if you like. I'm not sure why they are not showing in Disk Cleanup though. Did you click on the Clean up system files button in Disk Cleanup?
Will my program that i have installed deleted if i perform the repair install??
I have blue screen problem here. so i think to use the repair install to solve my problem.
i have the blue screen just now. It write the driver something. Not really sure what it is.
But I'm not sure should i using the repair install or system restore.
I did scan for affected program. here the pic.
Not sure what is the Microsoft(NETSERVICE). will it affect my OS.??
sorry for asking such question. I'm don't really have knowledge about the computer stuff. Hope that you guy's can help me. :)
Hello Akwardlkw, and welcome to Seven Forums.
A repair install will not affect installed programs, but you may or may not need to reinstall some drivers. You will only be able to do a repair install from within Windows 7 and not at boot.
Be sure to read all of the information and warnings at the top of the tutorial first.
Right now my O.S is the window 7 ultimate but if i'm using the windows 7 ultimate SP1 to repair install. can??
It must be the exact same edition and version as you have installed or it will not work.
The red warning box at the top of the tutorial can give more details on this though.
Actually... I'm curious about this also. I know that our own home made slipstreams are no good, but does the Digital River version with SP1 integrated work?
fark this has been a pain
i have win7 pro X64 oem came with my Lenovo laptop, I wanted to do a 7 sp1 repair install have tried downloading 4 different CD's the last being Win7 x64 Professional OEM and it told me it wanted to do an upgrade and that i need to use windows any upgrade
pulling my hair out
Which CD do i want for windows 7 Pro OA?
