Repair Install
Page 78 of 218 FirstFirst ... 68767778798088178 ... LastLast
  1. Posts : 9
    I dont know if I understand the tutorial correct,
    but how would I know if my Win7 installation disk has SP1 or not?
  2. Posts : 72,052
       #771
    Hello pspz,
    Open the folders below in your Windows 7 installation disc to open and read the license.rtf file. It will let you know what you have. :)
    sources\license\en-us\_default\ultimate\license.rtf
    Example at top of that file if it's with SP1:
    MICROSOFT SOFTWARE LICENSE TERMS
    WINDOWS 7 ULTIMATE SERVICE PACK 1
    These license terms are an agreement between Microsoft Corporation (or based on where you live, one of its affiliates) and you. Please read them. They apply to the software named above, which includes the media on which you received it, if any. Printed-paper license terms, which may come with the software, may replace or modify any on-screen license terms. The terms also apply to any Microsoft..........
  3. Posts : 9
    Tnx for the reply
  4. Posts : 72,052
       #773
    You're most welcome pspz. :)
  5. Posts : 8
    windows 7 Professional 64 bit
       #774
    Would I follow these steps if I'm getting crashes/BSOD/unexpected shut downs? and why in your steps do you select "compatible with windows vista?" when your actually only dealing with reinstalling windows 7 to repair it? is that just a 'work-around' to make it happen? I have installed win 7 myself once 2 years ago btw. 64 bit win 7 professional with outlook 2007 as well.
    thx so much, in advance
  6. Posts : 72,052
       #775
    Hello RW,
    Yep, that is just a workaround to be able to do the repair install when you do not have a Windows 7 with SP1 installation disc, but have a Windows 7 SP1 installation.
    For now, I would recommend to create a new thread about your crashes/BSOD/unexpected shut downs issues in the Crashes and Debugging forum area to see if we may be able to sort it first. Be sure to look at the link below to help show you what to include in your post there in order to help give you the best possible help with it. :)
    https://www.sevenforums.com/crashes-d...tructions.html
  7. Posts : 8
       #776
    I followed your steps to see if i have SP1 and it doesn't say i do. I installed win 7 myself with disc. Would i still follow these steps to repair my windows or not?
  8. Posts : 72,052
       #777
    Blue Screen of Death (BSOD) Posting Instructions
  9. Posts : 8
       #778
    I have no clue how to find errors in my system, but thanks. when blue screen came up, i barely saw it, and other times when i booted up, it had a message like " system shut down unexpectedly..." so i wouldn't know how to find error to follow up on it.
  10. Posts : 72,052
       #779
    Well, go ahead and post it there with any details you can provide, and see if you may be able to include what's at the link below in your post as well. With all of this, they may be able to determine what it wrong and help walk you through fixing it. Otherwise, you may be doing a clean install.
    At least this way we can have a crack at trying to get it fixed for you there. :)
