#830
Already have.
It's here :- Windows 7 will not recover with original DVD used to install it
Decided to give Repair Install a try using Option 5 but after I select Upgrade I get:-
Windows 7 Professional cannot be upgraded to Windows 7 Professional. You can choose to install a new copy of Windows 7 Professional instead, but this is different from an upgrade, and does not keep your files, settings, and programs. You’ll need to reinstall any programs using the original installation discs or files. To save your files before installing Windows, back them up to an external location such as a CD, DVD, or external hard drive. To install a new copy of Windows 7 Professional, click the Back button in the upper left-hand corner, and select “Custom (advanced)”.
Guess I'll need to wait for a solution to my BCD problem.
