Repair Install
  1. Posts : 72,050
       #1190
    igeorge said:
    Thank you Brink,
    I am looking now for a solutions which can let me do the same but booting from DVD
    Almost the same like a DVD upgrade
    Do you have any suggestion where i can find one
    I have the original one i bought first time with the official license, not pirate one, but this does not help
    I need an ISO of the upgrade DVD for windows 7 ultimate 64 without license.
    Maybe if i start the same process from the DVD , it will work ????
    Please let me know if you have a solution or suggestion
    Regards
    You will not be able to do a repair install at boot.
  2. Posts : 170
    Windows 7 Home Premium 64
       #1191
    A repair disk will not do an install, I understand, but need a little more education. I created a copy of the OEM Win7 Home Premium and a repair disk. The repair disk is bootable and will allow access to command prompt. Can I install (setup.exe) from the command prompt using the non-bootable disk?
  3. Posts : 72,050
       #1192
    Hello rdwray,
    Sorry, but no.
    You should be able to do a factory recovery from your recovery partition instead since this is an OEM computer.
  4. Posts : 1
    Windows 7 Hoome Premium x64
       #1193
    Thanks Shawn. I followed your instructions and it worked perfectly.
    Regards,
    Norman
  5. Posts : 170
       #1194
    Brink said:
    Hello rdwray,
    Sorry, but no.
    Is this another MS gotcha? Here we sit with a disk that cannot be copied, thereby, we do not have any safe resources.
  6. Posts : 72,050
       #1195
    Regards,
    Norman
    Glad it could Norman, and welcome to Seven Forums. :)
  7. Posts : 72,050
       #1196
    rdwray said:
    Brink said:
    Hello rdwray,
    Sorry, but no.
    No. It's an OEM factory computer gotcha.
    If you were wanting to do a repair install, then you should be able to use the note box under either step 4 or 5 to get a Windows 7 ISO file to use to do so. A repair install can only be done from within Windows.
  8. Posts : 170
       #1197
    Brink said:
    rdwray said:
    Brink said:
    Hello rdwray,
    Sorry, but no.
    Not much help when your HD dies and the original disc is history.
  9. Posts : 72,050
       #1198
    rdwray,
    Well, if you still have the product key from the COA sticker on your PC, then you could use the tutorial below to reinstall Windows if you like.
    Clean Reinstall - Factory OEM Windows 7
  10. Posts : 170
       #1199
    Brink said:
    rdwray,
    I was reading your instructions and got to 5 & 6; is not the Product Key listed in Belarc Advisor the same as the COA? My COA was on the palm rest and that got replaced .
