Repair Install
  1. Posts : 72,036
       #1500
    A repair install can only be done from within Windows since it's an in-place upgrade.
    It would be best to continue the restart freeze issue in your other thread below so this thread will not go off topic.
    Universal Theme Patcher Restart Freeze and Performance Light Always On
  2. Posts : 9
    Hi does the repair install remove Startup programs ?
    Thank you for your assistance
  3. Posts : 72,036
       #1502
    Hello Bladeg, and welcome to Seven Forums.
    No. :)
  4. Posts : 9
    Thanks it worked :)
  5. Posts : 72,036
       #1504
    You're welcome. Glad to hear it was able to help. :)
  6. Posts : 5
    Win 7 Home Premium with SP1
       #1505
    Installation hangs at Checking compatibility.
    This was a very nice, concise tutorial. However, the installation hangs at "checking compatibility". I ran it for about 8 hours last night, retried this morning and it's been stuck for about 2 hours. Does anyone have any suggestions what to try next. Reason trying to do repair install is that I can't do system repair, backups, clone HDD, or run spc/scannow. This computer is about 5 1/2 years old and I'm worried about HDD failure. Thanks in advance for your help.
    Mickey1
  7. Posts : 72,036
       #1506
    Hello Mickey, and welcome to Seven Forums. :)
    Do you have any installed 3rd party AV or firewall programs disabled or uninstalled? They can often interfere with a repair install like this.
  8. Posts : 5
       #1507
    Thanks Brink for your quick response. I did disable all anti virus and firewall apps, but it didn't help. I tried running program in safe mode, It got through "Checking Compatibility" but then pointed out that the program couldn't run in Safe mode. It identified a compatibility problem with iPhone app, which I removed. Still no glee.Any more thoughts. Thanks
    Mickey
  9. Posts : 72,036
       #1508
    If you are able to manually copy and paste any files that you do not want to lose to another location as a backup, then you might consider doing a clean install instead. It'll take more time, but you should be happier with the results in the end.
  10. Posts : 5
       #1509
    throwing in towel
    Thanks again Brink. I think that's the route I'll have to take. Can the custom installation on
    the repair disk perform a clean install?
    MickeyB
