Repair Install
Page 22 of 218 FirstFirst ... 12202122232432122 ... LastLast
  1. Posts : 8
    Windows 7 Home Premium
       #210
    Does it matter that I partitioned my disk? I think (from some comments in this tutorial) some people've had trouble with it.
    Also, would I have to reset my internet connection? I hate going through all that, because something will inevitably go wrong.
  2. Posts : 13,354
    Windows 7 Professional x64
       #211
    Nope, it doesn't matter. Whatever partition Windows is installed on will be repaired.
  3. Posts : 8
       #212
    Oh good.
  4. Posts : 130
    Windows® 7 Home Basic 64bit, Build 7600
       #213
    Is this applied only for most of RC's?
    I have on my laptop original installed Windows 7 Home ed.
    BTW, Great tut bro. and too!
    Thanks for sharing.
  5. Posts : 72,051
       #214
    Hello Elsuirad, and welcome to Seven Forums.
    If you are still using a RC build of Windows 7, then you will need to purchase a retail copy of Windows 7 very soon. The RC builds will expire on June 1st and will no longer work afterwards.
    Reminder: Windows 7 RC will expire Effective June 1, 2010.
  6. Posts : 128
    Windows 7 Ultimate 64-Bit
       #215
    Can I do a repair install by booting my system up to my installation disc rather then opening it inside of Windows? Because I can't open my installation disc in Windows because my system is pretty messed up right now.
  7. Posts : 13,354
       #216
    No, sorry, the repair install can only be done from within windows.
    You could do a custom install instead. It's a clean install, only you don't format.
    Read about it here: Custom Install Windows 7
  8. Posts : 4
    I got directed to this page for a solution to error 80072EFD. Does anyone know if this will fix my problem? And also, this solution doesn't delete any of my music or anything, does it?
  9. Posts : 13,354
       #218
    Repair Install won't touch music files at all. It affects only Windows files and maybe a few settings.
  10. Posts : 4
    ok and if I possibly misplaced my install disc am I just out of luck? or is their another way?
