Shortcut Arrow - Change, Remove, or Restore
Page 24 of 35 FirstFirst ... 14222324252634 ... LastLast
  1. Posts : 72,058
       #230
    Glad it could commychard, and welcome to Seven Forums. :)
  2. Posts : 54
    Windows 7 Professional
       #231
    Thanks, it works on Option 2!
  3. Posts : 14,606
       #232
    are you the same benjamin hall that was expelled from here a while back...
    if so can we have another epic thread it was epic.
    Epic thread
  4. Posts : 54
       #233
    No, I'm a different Benjamin...
  5. Posts : 14,606
       #234
    ah well.
  6. Posts : 1
    ElectricHumanBeing
       #235
    Can I remove icon's Arrow not for all Shortcuts but only for single Shortcut?
  7. Posts : 72,058
       #236
    Hello ElectricHuman, and welcome to Seven Forums.
    Unfortunately no. It's an all or none setting.
  8. Posts : 186
    Windows 7 Professional 32bit SP1, Windows 10 Home 64-bit at the moment
       #237
    OPTION ONE installs a program to remove the short-cut icons but its running all the time if you uninstall it and the short-cut icons come back so its a waste of resources.
    OPTION THREE works great its just a reg file and a blank icon in the Windows folder. and it also works on Windows 8. In fact it works on my Vista, Win7 and Win8 a really simple way to do it.
  9. Posts : 72,058
       #238
    Hello Keith,
    Just a FYI, but that's not true about OPTION ONE.
    The program does need to be installed to run it, but the program does not run all the time in the background, not does it need to. If you uninstall the program, it does not undo what changes you made to your shortcut arrow.
    The program is not required to be running or stay installed to keep your changes made to the shortcut overlay icon.
  10. Posts : 7
    Windows 7 Ultimate 64-bit
       #239
    If I delete the Shell Icons key, will it restore the default arrow, or will it cause problems?
