Log On Automatically at Startup
Page 3 of 15 FirstFirst 1234513 ... LastLast
  1. Posts : 124
    Brink said:
    I had it do it to me one time, and reapplying this tutorial here again made it stick afterwards. Not sure what caused it not to the first time though.
    I've reset everything in the POWER PLAN to either DISABLE, OFF or NEVER so I shall see when I re-boot.
    Thanks for your help.
  2. Posts : 2,036
    Windows 7 Professional x64
       #21
    I tried this from within a "standard user" account. It does not work. It needs to be done from within an administrator account to work. FYI
  3. Posts : 124
    Thanks Nate - it has now been sorted.
  4. Posts : 2,036
       #23
    Oh That's just general information for everyone to know. I didn't see it in the tutorial.
    Have a good day.
  5. Posts : 72,052
       #24
    Thank you Nate. I added this to the Warning box.
  6. Posts : 2
    W7
       #25
    Can you please explain how this option works on a pc with two user accounts? I'd like the ability to auto login to a specific user, but still allow the second user to login as needed. Is there some sort of time delay prior to auto login?
  7. Posts : 72,052
       #26
    Hello Jaminator,
    Sorry, but this option only allows for the one selected user account to be automatically logged on to at startup. The only way the other user can log on with this option enabled is to either "Switch User" (Start Menu) from with the other account and log on, or log off the other account and log on.
    With two users that both need to log on often, it may be best to not have automatic log on enabled.
  8. Posts : 6
    Windows 7 Ultimate
       #27
    Will this also work using Remote Desktop? It asks for your passsword/
  9. Posts : 72,052
       #28
    Hello Chris,
    Sorry but no.
  10. Posts : 8
    works greta to me thanks
