Introduction
Microsoft created Microsoft Security Essentials (MSE) to address a very simple problem: Too many PCs today are unprotected with either out-of-date anti-malware products or no anti-malware product at all.
Microsoft says there are a number of reasons for this:
  1. First, because many new PCs come with only a 30/60/90 day trial security solutions, some users believe they're protected even though the initial subscription period may have ended.
  2. Some don't even activate the free, bundled solutions at all.
  3. Some--especially those in emerging markets--can't or won't pay for security suites, most of which need to be renewed every year.
This tutorial will show you how to download, install, and configure this new free anti-malware option from Microsoft - Security Essentials
The release of the Microsoft Safety Scanner has resulted in confusion about the available anti-malware tools provided by Microsoft and questions about when they should be used.
Read more at: Understanding Microsoft Anti-Malware Software ~ Security Garden
If you wanted to manually download and install new definition updates for MSE, instead of updating them from within MSE, then see:
Install the latest Microsoft Security Essentials definition updates - Get the latest definitions - Microsoft Malware Protection Center
There's been a lot of interest in Microsoft Security Essentials and I think it will prove quite a hit with users. It's free, effective, lightweight, and quiet and is, in other words, exactly what I'm looking for in a security solution. And it comes with no strings at all. As long as you're running a genuine Windows version, you can install this product without worrying about up-sell advertisements, yearly renewals, or other silliness. And you can do so on as many Windows-based PCs as you own. I'd like to see it just included with Windows, but what the heck: Free and easy is the next best thing. Microsoft Security Essentials is highly recommended, to all Windows users.
--Paul Thurrott
September 29, 2009
Installation
First visit Microsoft's site devoted to all Security Essentials related material: http://www.microsoft.com/Security_Essentials/
That link may fizzle out over time, as MS likes to meddle with their websites often, if it dies... you can always google security essentials!
Once you arrive at the MS Security Essentials webpage, look for the "Download" button, and click it to start the download. See below:
Once your download starts you will be presented with the infamous; "what do you want to do with me now" dialog box. You can Run, Save, or Cancel. For the purpose of this tutorial, I'm hitting the easy button :sarc: and going with RUN. See below:
On my PC's I always choose SAVE first, and save to the built in downloads directory before I RUN and install any app. That way, I have an easy backup of any additional apps that I've ever been installed. Then if needed I don't have to search all over the Internet to reinstall them!
Now you will see the first of several install screens, as always click Next to continue.
Don't forget the 500 word legal mumbojumbo we never read... click Next to continue.
   Warning
image.php
Part of the installation involves MS validating your copy of Win7 as Genuine, so if you have a hacked, cracked, or jacked copy... sorry no free anti-malware for you!
This is the part of the install where your Win7 install will be validated, choose Validate to continue.
This portion of the installation is where you are warned that other anti-malware may interfere with the operation of MSE. Click Install to continue...
That's it... well almost! Once you click Finish, MSE will automatically connect to the MSE server and download the latest definitions...
If you leave the check mark in the box marked Scan my computer for... MSE will also run a Scan when it completes the definition updates
   Warning
It is always advised that you run a scan after installing any anti-malware!
Below is a screenshot of the Update Install process:
And the automatic scan after update completed:
Scan nearly complete after 8 minutes below:
Scan complete:
Your New MSE Interface
As we saw in the image above, when you are on the Home page of MSE, you have the option of scanning the PC in either Quick, Full, or Custom modes.
Naturally, the Update tab contains all the tools you need to keep your anti-malware definitions up to date.
The History tab will show you any detected and/or potentially harmful items, and the action taken on each item. It will also give you the name, alert level, and date.
The Settings tab is where you can change the way MSE works for you. You can schedule scans, change defaults, or turn real-time protection on or off. You can also exclude locations, types, and processes, etc. We will discuss the various changes you can make in the Configuration section below:
Configuration
The following section outlines the various configuration pages available in MSE, and what settings those contain.
For most users, the default settings for MSE are recommended!
On the image above you see the first page of many MSE configuration pages. It contains all the settings you need to change anything scan related... these screenshots depict MSE in it's outta the box or default mode.
Below you see the Default Actions settings page where you can change what MSE does when it detects a possible malware.
Here we see the Real-time protection settings... it;s on by default for a reason!
If you wish to exclude certain files or locations you can do so here:
   Warning
You are advised that while this may speed up scans it may leave your PC less protected.
Similar to the above settings this section below allows you to exclude certain file types from a scan.
And this page lets you exclude processes such as: .cmd, .bat, .pif, .scf, .exe, and .scr
The Advanced section allows you to scan archive files like .zip and .cab files, scan removable drives, create restore points automatically, and give you access to the History.
SpyNet is Microsofts online community that helps you choose how to respond to potential threats and helps prevent the spread of new malicious software. The last page allows you to choose your level of participation in this community.
Oh yes, when you have installed MSE it places an icon on your desktop and an icon in the notification area as shown below. You can access any of the configuration pages by double clicking on either icon.
Attachments not working dude. :(
Samsung NP530U4B-S02IN
Windows® 8 Pro (64-bit)
Samsung Electronics
1366x768
sucks
Google Chrome (Sync enabled)
Windows 7 Ultimate 64 bit Steve Ballmer Signa...Intel Core 2 Quad - Q9550 - 2.83GHz stock - O...4GB DDR2 800MHz (PC6400) OCZ ReaperNvidia GE Force 8800 GTS
Homebrew PC - "Alpha_Dawg"
Windows 7 Ultimate 64 bit Steve Ballmer Signature Edition
Intel Core 2 Quad - Q9550 - 2.83GHz stock - OC'd to 3.6GHz
Gigabyte EP45-UD3P
Asus Xonar DX
Samsung SyncMaster 2333HD
WD Caviar Black 750GB - 7200RPM - 32MB cache
WD Caviar Green 1.5TB - 5400RPM - 64MB cache
WD Caviar Green 2.0TB - 5400RPM - 64MB cache
PC Power & Cooling Silencer 750
Gigabyte 3D Aurora
Case is Air - 5ea. 120mm fans (mix of Arctic and Xigmatec)
MS Natural Wireless KB
MS Wireless Mouse
50 mbps down/5 mbps up
AVerMedia - AVerTVHD G2 Dual Tuner Card
Now its working. Nice tutorial. +rep.
Samsung Electronics
1366x768
sucks
Nice tutorial and well done...
Windows 7 Home Premium x64 - Mac OS X 10.6.4 x64Intel Core 2 Duo T9300 2.5 GHz4GB Kingston DDR2-800NVIDIA Geforce 8600M GT (512MB Model)
JFT02
WUXGA Standard Laptop Display
1680*1050
Standard Laptop Power Supply
Standard Laptop Case
Standard Laptop Cooling
Synaptics Touchpad
thanks for the tutorial, been using it for the pass two months and its pretty damn good.
One question though, is there any way to make it so it auto updates its definitions?
Yes, MSE can be set to update the malware definitions automatically and that's the default setting... I will finish the confiuration portion of the tutorial this evening!
AS you can see in the above image, if you have your MSE set at the default perform a scan automatically, it will first update definitions before doing so.
Gigabyte EP45-UD3P
Asus Xonar DX
Gigabyte 3D Aurora
MS Wireless Mouse
wont work on 64 bit
Windows 7 64 bit2300 Mhz clock speed - AMD Phenom 9650 Quad-Core2048+2048+2048+2048;DIMM Unknown SynchronousATI Radeon HD 3200 Graphics
NC684AA-ABA a6750y HP-Pavilion
Windows 7 64 bit
Phoenix Technologies, LTD )Phoenix - Award WorkstationBIOS v
HP w2007 Wide LCD Monitor
1680 x 1050 pixels
700 G + 1T ext.Drive
heat sinks + fans
Enhanced Multimedia PS/2 Keyboard
HID-compliant mouse
20000 mbps dwn 5000 up verizon Fios
only medium skills....just a hack
It works on 64 bit. Pick the appropriate one from the download link.
Airbot 2.0
Zotac Geforce GTX 770
ASUS Xonar D2X
1920x1080@60hz
1 Samsung 250GB 840 Evo SSD
1 OCZ Vertex2 180GB SSD
Pioneer DVD Burner DVR-S18M
Corsair HX1000W
Cooler Master HAF 932
Logitech Wireless MK700
DL 15 Mbps UL 0.98 Mbps
None
Firefox Nightly
*Phone- LG Nexus 5
Thanx Airbot , that worked out fine
Windows 7 64 bit
1680 x 1050 pixels
heat sinks + fans
HID-compliant mouse
hi Darryl, thanks for the tutorial. wich program is that at your desktop (the black one with the processor speed 2993Mhz)? I am having issues with asus pcprobe so I am looking another software wich gives me processor speed at least.. .it will be good to see the vcore and vid temps. thanks
dual: windows 7 Ultimate x64 7600 and XP SP3AMD PHENOM II 720 2800MHz2 X 2 OCZ REAPER 1066MHzMSI 4850 1GB OC
Personal Built (frankenstein) - WEI Here -> http://www.sevenforums.com/451826-post2094.html
ASUS M4A78 sb700
MSI 4850 1GB OC
REALTEK HD ONBOARD
LCD SAMSUNG 21" T220
1680 x 1050 - 60Hz
1.5 TB SEAGATE SATA II 7200 RPM
THERMALTAKE 430W PFC ACTIVE W0069
SOLID FULL ATX
COOLER MASTER TX-3 HEAT PIPES
logitech cordless keyboard
microsoft wireless
4Mb
sound system: logitech x540 5.1
Zboard Fang gaming keyboard
PS2 joystick
Philips VOIP fone
Any news out there regarding the automatic update and scheduled scan issues with MSE? Some complaints date back to 10/2009 and go on right up until today. There is registry tweak floating around that is supposed to change the update frequency to any interval between 1 and 24 hours. I applied the tweak to check once an hour but really can't confirm whether it is working or not.
What I can confirm is that the scheduled scan is buggy when using Vista or Win7. I have WIN7, VISTA, and XP computers and the XP computer is the only one that will consistently run a scheduled scan. The Vista and Win7 computers will run on schedule once or sometimes twice and then suddenly stop performing the scheduled scan. You fool around with the settings and it works a time or two and the same issues again.
I know this is a free software and probably doesn't rank very high on the "to do" list for Microsoft but when will these problems get fixed? Even free software is expected to function as intended. You would think 6 months would be enough time to implement a fix.
Win 7 Professional and Windows 8 Professional
Mine runs as scheduled each week for over 6 months now... on Win7 Pro.
Gigabyte EP45-UD3P
Asus Xonar DX
Gigabyte 3D Aurora
MS Wireless Mouse
I want to download and install MSE, but it requires validation as I'm not validating my Windows yet.
Then after validation is failed, Windows state my PC as not genuine, black screen and restart every hour.
Windows 7 Home Premium Service Pack 1 32-bit ...AMD C-50 Processor 1.0 Ghz2 GB DDR3 RAM (1.73 usable in System Properties)AMD Radeon HD 6200 series Graphics
Acer Aspire One 722 (AO722)
Windows 7 Home Premium Service Pack 1 32-bit Build 7601
High Definition Audio Device
Generic PnP Monitor
1366 x 768 (recommended)
320 GB HDD storage
298.09 GB in Disk Management (REAL)
Built-in on my laptop
External mouse
Installed Windows 7 Service Pack 1 by 9/9/2012
Activate the install now at Computer>Properties activation link. There is no reason to wait if you have a valid key. You can always reinstall or even (if not OEM) move a retail key as you please.
Windows 7 Pro x64 SP1Intel Core I716 GigsNVIDIA GeForce GTX 670M
Toshiba Laptop Qosimo X870
Intel Core I7
Toshiba Qosmio
16 Gigs
17.7" laptop
1600 x 900
256 Gig SanDisk SSD for C
256 Gig Intel SSD for D
50/25 FIOS
Vipre (all you can eat for 10 machines)
IE and FF
I have dos 6.22, wfwg 3.11, win98, 2000 and xp VHD's available for testing. MS's Virtual PC works great.
Samsung Electronics
1366x768
sucks
From the article:
While tests like these have no official standing, a look at AV-TEST’s longitudinal analysis of Security Essentials show it has consistently struggled to perform well in its malware detection and blocking tests.
Another security software testing organisation, Virus Bulletin, says Security Essentials’ performance is sufficient to justify its VB100 rating, which can only be attained by software that “prove it can detect 100% of malware samples listed as 'In the Wild' by the WildList Organization” without generating any false positives.
Since no industry standard seems to exist as to how these testing companies perform their tests, I'm not too concerned. A product that ranks # 1 today by one testing company might be # 10 (or lower) by another testing company. It's also interesting to note that Symantec (Norton) declined to take part in previous AV testing. I wonder why.
Participants 2012 - AV-Comparatives discussions - AV-Comparatives Forum
FWIW, even if a person chooses to use a product with a 50% detection rate, that's still 100% better than the person who uses nothing at all. :)
Sony Vaio VPCEB47GM Laptop
Win 7 Pro 64-bit
Intel i5 2.4 Ghz
8GB DDR3
Intel HD 3000
IDT High Definition
15.6 WGXA Anti-Glare LED
1280x800
640Gb 7200rpm
These tests are all rigged. There's too much cash sloshing around from the paid AV's who fleece billions out of unknowing millions with their preinstalled bloatware.
There's a reason MSE is recommended by those who know the OS best, especially the crash specialists who see the problems caused by the bloated AV's.
Stick with MSE which protects the same company's OS. Who would know it better? If a user is prone to infection upgrade Malwarebytes on-demand to real-time in addition.
