Favorites - Add or Remove from Navigation Pane
Page 12 of 13 FirstFirst ... 210111213 LastLast
  1. Posts : 72,058
       #110
    Anytime Rodger. :)
    Sorry, I was referring to C:\Windows\regedit.exe when saying regedit.
    The icon cache would not have any affect on this.
    The other question would be best posted as a new thread instead to keep this tutorial from going off topic. I'll be happy to help there when posted though.
  2. Posts : 1
    Hi all,
    Thanks for the guide. Now I have this problem (see the screenshot below), and I don't know how to fix it. Can you help me?
    Thanks in advance
    P.S. I have Windows 7 (I use a theme)
  3. Posts : 72,058
       #112
    Hello itacoop, and welcome to Seven Forums.
    That wouldn't be related to this tutorial.
    If you like, you should be able to do a system restore using a restore point dated before this happened to undo and fix it. :)
  4. Posts : 3
    windows 7 pro x64
       #113
    Hi, is there a way to remove the favorites-> Downloads folder only ? i dont want it for my users and i only found the option the disable the whole favorites pane. I want t o have Desktop & Recent locations available there but i want to remove Downloads folder. Is that possible?
    Cheers, Tyle
  5. Posts : 72,058
       #114
    Hello Tyle, and welcome to Seven Forums. :)
    You should be able to manually delete the folder in Favorites, but they will be able to add it back though.
  6. Posts : 3
    windows 7 pro x64
       #115
    Thanks ☺,
    true, but we have ~2000 users, is there a way with a command prompt, powershell or vbs script to delete it? Thanks for your time.
  7. Posts : 72,058
       #116
    You could use the command below in an elevated command prompt per account, but I'm not sure how to apply to all at once.
    RD /S /Q "%UserProfile%\Links\Downloads"
  8. Posts : 3
    windows 7 pro x64
       #117
    Awesome thanks so much, i have a central management tool to deploy it , thanks again
  9. Posts : 72,058
       #118
    You're most welcome. :)
  10. Posts : 170
    Windows 7 Home Premium 64
       #119
    This didn't work, checked all values to make sure they were entered:
    [HKEY\CLASSES_ROOT\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\ShellFolder]
    "Attributes"=dword:a9400100
    "PinToNameSpaceTree"=""
    [HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\ShellFolder]
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\ShellFolder]
