Favorites - Add or Remove from Navigation Pane
Page 1 of 13 12311 ... LastLast
    How to Add or Remove Favorites from Navigation Pane in Windows 7
    This tutorial will show you how to add or remove the Favorites folder in the Windows Explorer Navigation Pane in Windows 7.
       Tip
    The default folder for Favorites is the Links folder located at the location below.
    C:\Users\(user-name)\Links
       Warning
    • You can only do this while logged into an administrator account.
    • This will affect all user account's on the computer.
    EXAMPLE: Favorites in Navigation Pane
    NOTE: This is the Favorites group added (default) (left screenshot below) and removed (right screenshot below) from the Navigation Pane.
    Here's How:
    1. Open the Start Menu and type regedit.exe in the search line, then press enter.
    3. In Regedit, go to the location below: (See screenshot below step 4)
    HKEY\CLASSES_ROOT\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\ShellFolder
    4. In the left pane of regedit, right click on the ShellFolder key and click on Permissions. (See screenshot below)
    5. At the top, select the Administrators group. At the bottom, check the Allow box to the right of Full Control and click on OK. (See screenshot below)
    6. In the right pane of regedit, right click on Attributes and click on Modify. (See screenshot below)
    7. To Add Favorites to the Navigation Pane
    A) Type in a0900100 and click on OK. (see screenshot below)
    B) Go to step 9.
    8. To Remove Favorites from the Navigation Pane
    A) Type in a9400100 and click on OK. (see screenshot below)
    9. If you have 64-bit Windows 7 Installed
    CREDIT TO: Kookster for this addition.
    To also add or remove Favorites from the "Open" and "Save as" type windows as well in 64-bit Windows 7, you will also need to do this step.
    If you have a 32-bit Windows 7 installed, then skip this step since doing steps 1 to 7/8 will add or remove Favorites from the "Open" and "Save as" type windows as well.
    A) In Regedit, go to the location below:
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\ShellFolder
    B) Repeat steps 4 to 7/8 above.
    10. Close regedit.
    11. Restart the computer to fully apply.
  1. Posts : 18,404
    Thanks Shawn. I failed to find any info on how to remove it before. :)
  2. Posts : 72,052
    You're welcome Aaron. :)
  3. Posts : 6
    windows 7
    Remove Personal Folder
    Do you have a registry entry to remove the personal folder from the navigation pane? i.e. the one with your name containing the basics, My Music, My Videos, etc.
    Thanks,
  4. Posts : 72,052
    Hello Vijer,
    I'll look into a way for you and post back if I find one. For now, you can uncheck the Show all folders option when you right click on a empty space in the navigation pane to remove it. :)
  5. Posts : 72,052
  6. Posts : 6
    windows 7
    Thanks for doing that so quickly.
    Too bad all of these hacks are not part of the Personalization settings on the Control Panel. I can never figure out why Microsoft makes it so users can hack the settings but doesn't make it part of the UI. It would go a long way towards making the user community a lot happier with the Microsoft OS's.
  7. Posts : 72,052
    You're welcome Vijer. Yeah, that would be nice to have a GUI for every setting possible. :)
  8. Posts : 2,651
    W7 RTM Ultimate x64
    Is there a tutorial on how to change the Icon for the Favorites?
  9. Posts : 72,052
    Hello Enzo,
    No, but you can go the registry location below, then do steps 4 & 5 for the DefaultIcon key. Afterwards, right click on (Default) in the right pane, and click on Modify. Type in the full path of the icon you want to use. You may need to log off and log on to fully apply though.
    See tutorial: Favorites - Change Default Icon
    HKEY_CLASSES_ROOT\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E}\DefaultIcon
