Windows 7: Homegroup - Add or Remove from Navigation Pane
25 Aug 2012   #10
Brink
64-bit Windows 10 Pro
Yep, this one is not working properly on Windows 8 yet.
25 Aug 2012   #11
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Quote   Quote: Originally Posted by Brink View Post
Thanks mate, I guess I'll go set the values back to default just to be on the safe side.
06 Nov 2012   #12
ksdixon
I'm in Windows 8 too (Pro, x86 due to upgrading an older OEM PC), and I pulled up Services and disabled the two HomeGroup services. After a restart HomeGroup has not reappeared in my windows explorer left navigation pane.
06 Nov 2012   #13
Brink
Hello lilsting,
That will do fine as long as you do not want to create or join a Homegroup.
20 Mar 2013   #14
Conditioned
Tomatoe
Any chance of automating this? How do you change perms in batched in the registrY?
20 Mar 2013   #15
Brink
Hello Conditioned,
I'll add it to the list to look into, and post back if I'm able to get it to work properly.
24 Oct 2013   #16
speedgamer01
Windows 7 Ultimate 64 bit SP1
I'd like to add an alternative way of removing homegroup
09 Feb 2014   #17
b33z
Perfect! didn't even have to restart!
cheers!
13 Mar 2016   #18
xFiReStOrMx
Windows 7 Home Premium 64bit / Windows 10 Pro 64bit
Quote   Quote: Originally Posted by speedgamer01 View Post
The way provided on here is pretty simple, but yeah no doubt that way is for sure much easier and quicker and you are disabling the services too, but I am not sure if the method provided on here would have done that also.
Either way thanks to all!
Favorites - Add or Remove from Navigation Pane
How to Add or Remove Favorites from Navigation Pane in Windows 7 This tutorial will show you how to add or remove the Favorites folder in the Windows Explorer Navigation Pane in Windows 7. The default folder for Favorites is the Links folder located at the location below. ...
Tutorials
Recycle Bin - Add or Remove from Navigation Pane
How to Add or Remove Recycle Bin from Navigation Pane in Windows 7 The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full. This...
Tutorials
Computer - Add or Remove from Navigation Pane
How to Add or Remove Computer from Navigation Pane in Windows 7 This will show you how to add or remove Computer in the Windows Explorer Navigation Pane in Windows 7. You can only do this while logged into an administrator account. This will affect all user account's on the computer....
Tutorials
Network - Add or Remove from Navigation Pane
How to Add or Remove "Network" from the Windows 7 Navigation Pane This will show you how to add or remove Network in the Windows Explorer Navigation Pane in Windows 7. You can only do this while logged into an administrator account. This will affect all user account's on the...
Tutorials
Homegroup - Rename in Windows 7 Navigation Pane
How to Rename "Homegroup" in Navigation Pane in Windows 7 and Windows 8 This tutorial will show you how to rename the Homegroup folder in the Navigation Pane to any name that you like for all users in Windows 7 and Windows 8. You must be logged in as an administrator to be able to do the...
Tutorials
Remove WMP12 Navigation Pane>
Is it possible to remove (hide) the navigation pane in WMP12. I've done searches and scanned the registry and can't seem to find a way. Anyone know if it's possible?
General Discussion
