Windows 7: Homegroup - Add or Remove from Navigation Pane
How to Add or Remove Homegroup from Navigation Pane in Windows 7
Published by Brink
17 Nov 2009
information   Information
This will show you how to add or remove Homegroup in the Windows Explorer Navigation Pane in Windows 7.
warning   Warning
  • You can only do this while logged into an administrator account.
  • This will affect all user account's on the computer.
EXAMPLE: Homegroup in Navigation Pane
NOTE: This is Homegroup added (default) (left screenshot below) and removed (right screenshot below) from the Navigation Pane.
Here's How:
1. Open the Start Menu and type regedit.exe in the search line, then press enter.
3. In Regedit, go to the location below: (See screenshot below step 4)
HKEY_CLASSES_ROOT\CLSID\{B4FB3F98-C1EA-428d-A78A-D1F5659CBA93}\ShellFolder
4. In the left pane of regedit, right click on the ShellFolder key and click on Permissions. (See screenshot below)
5. At the top, select the Administrators group. At the bottom, check the Allow box to the right of Full Control and click on OK. (See screenshot below)
6. In the right pane of regedit, right click on Attributes and click on Modify. (See screenshot below)
7. To Add Homegroup to the Navigation Pane
A) Type in b084010c and click on OK. (see screenshot below)
B) Go to step 9.
8. To Remove Homegroup from the Navigation Pane
A) Type in b094010c and click on OK. (see screenshot below)
9. If you have 64-bit Windows 7 Installed
Note   Note
CREDIT TO: Kookster for this addition.
To also add or remove Homegroup from the "Open" and "Save as" type windows as well in 64-bit Windows 7, you will also need to do this step.
If you have a 32-bit Windows 7 installed, then skip this step since doing steps 1 to 7/8 will add or remove Homegroup from the "Open" and "Save as" type windows as well.
A) In Regedit, go to the location below:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{B4FB3F98-C1EA-428d-A78A-D1F5659CBA93}\ShellFolder
B) Repeat steps 4 to 7/8 above.
10. Close regedit.
11. Restart the computer to fully apply.
Related Tutorials
05 Feb 2010   #1
vonesser
Re: How to Add or Remove Homegroup...
Will this also remove the icon from my desktop? That's all I would care about. All other computers on my home net are XP, so Homegroup is superfluous to me.
Nick
05 Feb 2010   #2
Brink
64-bit Windows 10 Pro
Hello Nick,
I don't believe it will, but if it does, then you should be able to use this.
HomeGroup Desktop Icon - Add or Remove
05 Feb 2010   #3
vonesser
Do I have to do both, or will the downloaded reg file merge alone work?
05 Feb 2010   #4
Brink
No, do the one here first to see if it is removed from the desktop first. We can go from there if needed.
20 Apr 2010   #5
iottt
Windows 7,Vista,XP
thanx m8, home group and other links were getting really annoying, especially when i opened a small open or save file dialogue, i couldn't see my favorites because the space was taken up by homegroup and libraries
20 Apr 2010   #6
Brink
You're most welcome Iottt, and welcome to Seven Forums.
03 Jul 2012   #7
cmhp2111
on my laptop: Win7 home premium x64
Thanks, Brink! My laptop is my only Win7 computer and the homegroup in the Navigation tab was driving me crazy. This tutorial worked perfectly!
03 Jul 2012   #8
Brink
You're most welcome cmhp2111, and welcome to Seven Forums.
25 Aug 2012   #9
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Hello Shawn.
This is odd in Windows 8, Homegroup goes away but on a reboot it's back.
Favorites - Add or Remove from Navigation Pane
How to Add or Remove Favorites from Navigation Pane in Windows 7 This tutorial will show you how to add or remove the Favorites folder in the Windows Explorer Navigation Pane in Windows 7. The default folder for Favorites is the Links folder located at the location below. ...
Tutorials
Recycle Bin - Add or Remove from Navigation Pane
How to Add or Remove Recycle Bin from Navigation Pane in Windows 7 The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full. This...
Tutorials
Computer - Add or Remove from Navigation Pane
How to Add or Remove Computer from Navigation Pane in Windows 7 This will show you how to add or remove Computer in the Windows Explorer Navigation Pane in Windows 7. You can only do this while logged into an administrator account. This will affect all user account's on the computer....
Tutorials
Network - Add or Remove from Navigation Pane
How to Add or Remove "Network" from the Windows 7 Navigation Pane This will show you how to add or remove Network in the Windows Explorer Navigation Pane in Windows 7. You can only do this while logged into an administrator account. This will affect all user account's on the...
Tutorials
Homegroup - Rename in Windows 7 Navigation Pane
How to Rename "Homegroup" in Navigation Pane in Windows 7 and Windows 8 This tutorial will show you how to rename the Homegroup folder in the Navigation Pane to any name that you like for all users in Windows 7 and Windows 8. You must be logged in as an administrator to be able to do the...
Tutorials
Remove WMP12 Navigation Pane>
Is it possible to remove (hide) the navigation pane in WMP12. I've done searches and scanned the registry and can't seem to find a way. Anyone know if it's possible?
General Discussion
