Hi, just an update with my findings in windows 7 RTM. For the taskbar the images is the same as in 7229.
I also made a pic to display what numbers the pictures have for a window.
Finally you can use Universal Theme Patcher to patch windows 7
TCP-Z, Best TCP/IP Patch: Universal Theme Patcher (v1.5, Build 20090409)
i downloaded ux theme patch,, and when i open the dll file in resource tuner,, i cant find ne images? that match what you described,, ne help ?? plz
Can someone attach files for blue start menu, windows 7 final?
really really really new to this where do i find the files that i have to patch for the uxtheme patch ?
You will get all the files and instructions you need in the zip file that contains the theme you have downloaded from deviantart.com.
Here is one black that I use:
Ultimate for Windows 7 Basic by ~MediaMyself on deviantART
But there is many, try to search for "windows 7 basic" on deviantart.
Hi
I just made a black magic for the taskbar, when you are in basic mode.
And thx for the great advice here to do it.
Just upgraded to Windows 7 Ultimate (32 bit) today - but I'm confused... when I go into the Aero folder I have to go farther, into the en-US folder... and then I find aero.msstyles.mui ... and I don't know what an MUI file is. Tried replacing it, to no avail. Is this something that is occuring on newer releases of Windows 7? Or am I just too computer illiterate to know what's going on? :)
