Disk Check
How to Run Disk Check in Windows 7
This will show you how to run Check Disk or chkdsk in Windows 7 to check a selected hard disk for file system errors and bad sectors on it.
Running a check disk may take a bit depending on the size of the selected hard disk. For faster and better results, do not use your computer while check disk is checking for errors.
You will have a choice to scan only, scan for and attempt to fix errors, scan for and attempt recovery of bad sectors, or scan for and attempt to fix errors and recovery of bad sectors.
OPTION ONE
To Run Chkdsk from Drive's Properties Page
1. Open the Start Menu and click on the Computer button on the right dark side.
2. Right click the hard disk drive that you want to check, and click on Properties. (see screenshot below) Computer.jpg
3. Click on the Tools tab, and click on the Check now button under Error-checking. (see screenshot below) Properties.jpg
4. You will now see this window. Do the steps below for what you would like to do. (see screenshot below) Options.jpg
5. To Only Scan the Drive for Errors
NOTE: This will just give you a report if there are any drive errors or not, and will not attempt to fix them. A) Leave both boxes unchecked and click on the Start button. (see screenshot below step 4)
6. To Only Scan and Attempt Recovery of Bad Sectors
NOTE: This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete. A) uncheck the Automatically fix file system errors box. (see screenshot below step 4)
B) Check the Scan for and attempt recovery of bad sectors box.
7. To Only Scan and Automatically Attempt to Fix Errors
NOTE: This will automatically attempt to repair problems with files and folders that the scan detects. A) Check the Automatically fix file system errors box. (see screenshot below step 4)
B) Uncheck the Scan for and attempt recovery of bad sectors box.
8. To Scan and Automatically Attempt to Fix Errors and Recover Bad Sectors
NOTE: This will scan for both file errors and physical errors (steps 6 and 7). It will then attempt to repair problems with files and folders, and recover physical errors. A) Check the Automatically fix file system errors box. (see screenshot below step 4)
9. Click on the Start button, and do either step 10 or 11 below depending on if the drive is currently in use or not. (see screenshot below step 4)
10. If the selected hard disk is not in use, then you will see check disk start checking the disk now. (see screenshot below) Step4A.jpg
A) When the scan is complete, you will then see
results similar to this. Click on Close. (see screenshots below) Details.jpg
B) Click on OK. (see screenshot below step 3)
C) Stop, you're done.
11. If the selected hard disk is in use, then click on the Schedule disk check button. (see screenshot below)
NOTE: If the hard disk that you selected in step 2 is in use (for example, the C: drive or partition that contains Windows 7), you'll be prompted to reschedule the disk check for the next time you restart your computer. Otherwise you will not see this window below. Schedule.jpg
A) Restart the computer.
B) During startup, you will only have 10 seconds to press a key to cancel the Disk Check from steps 7 or 8. (see screenshot below)
   Warning
Once the Disk Check scan starts, DO NOT STOP the scan to prevent possible damage to the data on your hard drive.
C) When the scan is complete you will see a report similar to this below briefly before the computer automatically restarts. Start-up.jpg
OPTION TWO
To Run Chkdsk from Command Prompt
NOTE: The chkdsk command can be used on a FAT32 or NTFS formatted disk. 1. Open a elevated command prompt or a command prompt at startup.
2. In the command prompt, type in the following command below followed by one or more switches that you would like to use below with a space between each switch and press Enter.
NOTE: For example, the most common command to run chkdsk on your C: drive is: chkdsk C: /F
chkdsk [drive letter]: [switches with space inbetween]
Switches that you can use in the command:
  • /F - Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer. For example, on the C: drive.
  • /V - Displays the name of each file in every directory as the disk is checked.
  • /R - Locates bad sectors and recovers readable information. The disk must be locked. /r includes the functionality of /f, with the additional analysis of physical disk errors.
  • /L:[size in KB] - Can only be used with a NTFS disk. Changes the chkdsk log file size to the number size in KB you type. If you omit the size parameter, typing /L by itself will display the current chkdsk log file size. For example, to have the default 65536 KB log file for the C: drive, you would type: chkdsk C: /F /L:65536
  • /X - Forces the volume to dismount first, if necessary. All open handles to the drive are invalidated. /x also includes the functionality of /f.
  • /I - Can only be used with a NTFS disk. Performs a less vigorous check of index entries, which reduces the amount of time required to run chkdsk.
  • /C - Can only be used with a NTFS disk. Does not check cycles within the folder structure, which reduces the amount of time required to run chkdsk.
  • /B - Can only be used with a NTFS disk. Clears the list of bad clusters on the volume and rescans all allocated and free clusters for errors. /b includes the functionality of /r. Use this parameter after imaging a volume to a new hard disk drive.
In addition to SeaTools the WD diagnostic tool is
WinDlg
You may want to run the Quick tests first.
Windows 7x64 Home Premium SP1Intel i7 2600kG.Skill Ripjaws (DDR3-1600) 2x4GBNvidia GeForce GTS 450; Intel HD Graphics 300...
Own build
Intel i7 2600k
ASUS P8Z68 Deluxe
Seasonic M12II 520W
Lian Li Lancool PC-K60
Logitech MK520 (wireless)
Logitech MK520
6-7 Mbps
FireFox
Audio: Logitech Z523 2.1
Hi Brink and mjf,
I just ran WinDlg on my drive and it shows error code=07 failed read test element, failure 97 and based on WinDlg manual, it said read element failure and I have to RMA the HD. Fortunately it's still under warranty until 09/08/2014 so I guess, I will RMA it and get replacement from WD. Thank you so much for all the help.
Windows 7 Ultimate x64I5 4570Corsair Vengeance PC-12800 2x8GBAsus Geforce 770
I5 4570
Asus X97-A
Asus Geforce 770
WD Black 1.5TB
External WD Blue 1TB
Sorry to hear that Anbu. Hopefully they'll get you a replacement soon.
Hello this is the first post for me ever.
I get something wrong here when I start this process, It was taking a lot of time and I cancelled it. That processing was on E.
Then E doesn't want me to get in him. loooool.
Please what should I do please?
Windows 7 Ultimate x64i5nividia
Toshiba
i5
nividia
Google chrome
Will take a long time (1hour+ depending on the size of the HDD). The Seagate and WD diagnostics provide a quick check option. This doesn't substitute for a full scan but if they fail you'll know sooner that you have a problem.
Own build
Intel i7 2600k
ASUS P8Z68 Deluxe
Seasonic M12II 520W
Logitech MK520
6-7 Mbps
FireFox
I don't understand why, given after a crash Windows will give you the option to "Start Windows normally", that it doesn't also have some built-in way to prompt the user to do a Disk Check. I often end-up forgetting about the abnormal shutdown of Windows and the possible disk corruption that may have resulted.
Does anyone here know of a method or utility that will enable me on bootup to select a Disk Check without having to go all-the-way in Windows and set-it-up manually and reboot yet again?
Windows 7 Professional 64bitIntel Core i7 4600M @ 2.90GHz16.0GB Dual-Channel DDR3 @ 797MHz (11-11-11-28)Intel HD Graphics 4600 (Dell) 2048MB ATI AMD ...
Dell Latitude E6540 Laptop
Dell Inc. 0CYT5F (SOCKET 0)
Intel HD Graphics 4600 (Dell) 2048MB ATI AMD Radeon HD 8790M
HP ZR30w (2560x1600@60Hz)
256GB LITEONIT LMT-256M6M-41 mm SATA (SSD)
1TB Samsung SSD 860 EVO mSATA SATA (SSD)
2TB USB 3.0 USB Device
115GB SanDisk Ultra Fit USB
Multiple Dell E-Port Plus II Port Replicator/Docking Stations 0Y72NH USB 3.0 + 130W AC Adapters
Hello Max,
You could open a command prompt at boot and run chkdsk using OPTION TWO in the tutorial. :)
Hmmm what's the easiest way to "open cmd.exe at boot". I know there's a Repair thingie somewhere (maybe F8?) but now you have me thinking an EasyBCD menu item. Thanks for yr reply!
Is it possible to run chkdsk on multiple drives?
Whilst restarting Windows first - similar to running chkdsk on drive c:
Hello sfwul,
You can run chkdsk in separate command prompt window per drive to be able to run chkdsk on multiple drives simultaneously. :)
Thanks.
For good order's sake: in my post, 2nd line at the end, I wrote a 'c:' plus a ')' which was confusing as it returned into a smiley, obviously.
what I meant is:
RMB C-drive properties->tab Tool -> [Check now...]
offers users to schedule a chkdsk, so it next reboot it will run the chkdsk.
My idea was then to run it multiple drives - it will take hours, so I would then go on to do something else in the meantime.
But you are right (of course...): the task can be performed running it from multiple CMD sessions.
Didn't of it.
I'm not aware of a way to schedule it to automatically run on multiple drives at boot like that. The only workaround that I know of are the multiple CMD sessions. :(
I discovered I had and error on my computer when I tried to make a backup and a system image in case there was a future problem with this computer and I do not want to lose very important sorftware I can not get again.
So I tried to do a check disk and selected fix errors. then I got the message it can not do it because "C" is being used, then i followed the instructions I saw in here about scheduling it after start up & to be careful to not cancel it....OK so i restarted immediately after clicking the "schedule thing" and waited and waited and waited, until me desktop is sitting there and nothing seems to be going on....zip...nota...how do I get this dang check disk thing to work?
Windows 7 Home Professional
HP EleteBook 8740w
PC Matic
Brave
Hello, and welcome to Seven Forums. :-)
If you like, you could use option 2 to manually run chkdsk in a command prompt at boot.
Can you show me how to do that? I am not exactly a computer Gu Ru.
I heard the term command prompt but dont know how to find it, open it or use it.
HP EleteBook 8740w
PC Matic
Brave
The tutorial below can help show you how to open a command prompt at boot.
Command Prompt at Startup
From there, it's just a matter of following the steps in option 2 on the first post here.
If you have any questions on the steps, please just let me know. :-)
