Virtual Private Network (VPN) - Enable Incoming VPN Connections
  1. Posts : 2
    Windows Premium x64
       #20
    Great tutorial!
  2. Posts : 10,796
       #21
    In https://www.sevenforums.com/attachmen...nections-7.jpg I checked "allow callers to access my local network". I checked "specify ip addresses" as well. But what to fill in at "From:" and "To:" ? It must be possible that 10 vpn-clients connect simultaniously
    My home lan has IP-addresses 192.168.10.1 (router), 192.168.10.2 (ftp server with static ip address), 3 computers in dhcp-range (192.168.10.100-192.168.10.200). subnetmask=255.255.255.0
  3. Posts : 10
    Windows 7 x64
       #22
    Hi, I did this and I can connect only once to my Win 7 Ultimate machine, is there a way to allow multiple PPTP connections?
    Thanks!
  4. Posts : 10
    Windows 7 x64
       #23
    Since Win7 only allows 1 connection I am using OpenVPN and so far I have 3 PC's, 1 Mac, 1 Linux and 2 Android phones connected and working fine. Only thing im missing is the iPad2 which there is no OpemVPN on Apple AppStore for it.. And I cant use both Win7 and OpenVPN at the same time since I have to ICS the local nic to one of the VPN adapters..
  5. Posts : 1
    Windows 7 64
       #24
    Error message "Windows could not detect any devices"
    When I try to configure my VPN, I get an message when I am setting up a new incoming connection that says
    Windows could not detect any devices".
    Okay.. I am stumped.. How do I get around this?
    Thanks in advance for your help
  6. Posts : 10
    Windows 7 x64
       #25
    I am now using a pfSense firewall that has IPSec, L2TP, PPTP and OpenVPN :) Only using the later 2 at the moment.. MS should not cripple their software to make you buy an upgrade...that's just...wrong.
  7. Posts : 6
    Windows 7 Ultimate 32bit
       #26
    Hi there,
    What I need and been trying to setup somehow with a script I found over the net, is a DRC on windows 7 start. But I need to conect to this windows 7 start PC. But according to MS it can only be a client. Does anybody have any ideas ?
    Take care.
  8. Posts : 10,796
       #27
    cgandara said:
    Hi there,
    Take care.
    you mean RDC (remoet desktop connection) instead of DRC?
    What doesn't work?
    • setting up win7 as a terminal server?
    • Connect to that terminal server?
  9. Posts : 6
       #28
    Kaktussoft said:
    cgandara said:
    Hi there,
    Take care.
    What doesn't work?
    Yes, that what I meant, RDC. Well what I am trying to do is to have my windows XP PC conects to my windows 7 start PC using RDC>
  10. Posts : 10,796
       #29
    What doen't work?
    is win7 terminal server running fine? let another computer in house try to connect to it. First terminal server has to be up and running succesful.
