Virtual Private Network (VPN) - Enable Incoming VPN Connections
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 6
    Windows 7 Ultimate 32bit
       #30
    Kaktussoft said:
    What doen't work?
    is win7 terminal server running fine? let another computer in house try to connect to it. First terminal server has to be up and running succesful.
    Thatīs my scenario.
    3 -PCs running Windows XP
    1 - PC running Windows 7 Start ( role as "Server" )
    I need to use RDC to conect to this Windows 7 Starter.
    Do you understand now ?
  2. Posts : 10,796
       #31
    none of the winxp clients can connect to win7 server?
    What doe you mean by "Windows 7 Starter"?
    how did you start terminal server on win7?
  3. Posts : 6
       #32
    I am from Brazil, and here we have these versions of windows :
    Windows 7 Starter Edition
    Windows 7 Home Edition
    Windows 7 Home Preminum Edition
    Windows 7 Professional Edition
    Windows 7 Ultimate Edition
    In one of my PC I have Windows 7 Starter Edition. So, I am trying to conect my WinXP PC to this PC using RDC.
  4. Posts : 10
    Windows 7 x64
       #33
    Use VNC or (behind FW) TeamViewer, there is also logmein...
  5. Posts : 6
       #34
    That I know, but I want to use RDC.
    Thanks.
  6. Posts : 10
    Windows 7 x64
       #35
    Thanks.
    Unfortunately what we are trying to say here is RDP server is win7pro and up. Either accept one of those alternatives or give up.
  7. Posts : 6
       #36
    m4f1050 said:
    Thanks.
    I came across a script I found on the net. I tried it, but it didinīt work.
  8. Posts : 10,796
       #37
    cgandara said:
    m4f1050 said:
    Thanks.
    please run in command prompt:
    REG QUERY "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion" /v "ProductName"
    And post ouput
    what script and from where?
  9. Posts : 7
    Windows 7 Ultimate 64-bit
       #38
    hi, sorry for posting the same thing into multiple threads, but is it possible to set the Windows VPN Server to allow the connected devices to access the internet via the VPN tunnel? (e.g. "share" the server's Internet connection with the connected hosts)
    I need to set the server like this because when I connect my Android phone to VPN it looses the Internet connection and can access only the LAN. The VPN server (W7 Ultimate x64) doesn't let it go beyond the LAN (--> to the Internet).
  10. Posts : 4
    Windows 7 RC build 7100
       #39
    Hi all. I've been trying to work it out a lot since my Win2003 Served died of old age - so I had to reuse my Router in order to access my old desktop - running Windows 7. Now that RDP works because I have port forwarded in the router, I need VPN also.
    I have done everything as it should. I even kicked off my Firewall in order to be sure I was not doing smth wrong. But still:
    Event ID's: 4648, 4624, 4672, 4634 on every failed attempt to remotely log in and of course Error 720 , 800 even 647 - ( account disabled ) on the client.
    WHAT IS WRONG?
Đ Designer Media Ltd
