How to Change the Windows 7 Problem Reporting Settings
Sending problem reports to Microsoft helps Windows 7 to check and identify problems and notify you about any found solutions.
This will show you how to change the Problem Reporting Settings to when and what is sent to Microsoft, or to turn off checking for solutions.
EXAMPLE: Check for Solutions NOTE: This is what you will see when Windows 7 is checking for a solution for a problem report.
Here's How: 1. Click on the Action Center icon in the notification area of the taskbar, and click on Open Action Center. (See screenshot below)
A) Go to step 3.
OR
2. Open theControl Panel (All Items View). A) Click on the Action Center icon.
3. Click on the Maintenance drop down arrow to expand it, then click on the Settings link under the Check for solutions to problem reports section. (See screenshot below)
4. To Change Only Your Report Settings
NOTE: This will be grayed out unless you (administrator) have selected the Allow each user to choose settings option in step 5 below, you have error reporting turned on and/or enabled.
A) Select when to check for solutions to problem reports, and click on OK. (See screenshots above)
B) Go to step 6.
5. To Change All Users Report Settings
NOTE: You will need to be logged in as an administrator to be able to change the settings in this step.A) Click on the Change report settings for all users link. (See screenshots below step 4)
B) Select what problem report settings you want to use for all users on the computer, and click on OK. (See screenshot below)
C) Do step 4.
6. When done, close the Action Center window. (See screenshot below step 3)
