Windows 7: Power Efficiency Diagnostics Report
How to Run a Power Efficiency Diagnostics Report in Windows 7 and Windows 8
Published by Brink
27 Feb 2009
information   Information
The Power Efficiency Diagnostics will analyze your system for common energy efficiency and battery life problems, and report any errors, warnings, and informational details found.
This tutorial will show you how to run a power efficiency diagnostics report of your computer in Windows 7 and Windows 8.
warning   Warning
You should run this report when your computer is idle and with no open programs or documents for the best results.
Here's How:
1. Open an elevated command prompt in Windows 7 or Windows 8.
2. In the elevated command prompt, copy and paste the command below, and press Enter. (see screenshot below)
NOTE: This will take 60 seconds to run by default. When done it will give you a quick report of any poroblems found and place a detailed Energy_Report.html file on your desktop.
powercfg -energy -output %USERPROFILE%\Desktop\Energy_Report.html
Note   Note
You could also change the command to be able to use your own location for where you want the Energy_Report.html file to be placed (outputted) at.
powercfg -energy -output "C:\Full Path\Energy_Report.html"
3. Double click on the Energy_Report.html file on your desktop to open and see the power efficiency diagnostics report in Internet Explorer. (See screenshot below)
4. This is a copy of my power efficiency diagnostics report in Internet Explorer as an example of what you can see. (See screenshots below)
Tip   Tip
For more information about how to read Powercfg energy reports, you can read the paper "Using PowerCfg to Evaluate System Energy Efficiency" available from the following Microsoft website below as a .docx file.
27 Feb 2009   #1
Dinesh
Windows® 8 Pro (64-bit)
helped me to check my laptop battery life.
Nice one Shawn.
27 Feb 2009   #2
Brink
64-bit Windows 10 Pro
Hello Dinesh.
Yeah, the -energy extension is a nice addition to the powercfg command in Windows 7. Very nice.
15 Sep 2010   #3
hariharan
Windows Vista Home Premium x86, Home Premium x86
Is this option Available for Windows Vista?
15 Sep 2010   #4
Brink
Hello Hariharan,
Sorry, but it's not available in Vista. It's a new feature in Windows 7.
24 Nov 2010   #5
RJL24
Main: WIN7 Pro, 64 bit; Notebook Windows 7 Home Premium
OK now I have the report, but what do I do with it in order to correct the seeming USB issues? Please be very specific, as I require detailed instructions. Thanks in advance.
24 Nov 2010   #6
Brink
Hello RJl24,
If you are referring to your issue that you posted at your thread below, then this report has nothing to do with that.
Something went amiss
24 Nov 2010   #7
RJL24
Actually, that issue of something went amiss
has been resolved, please see the thread.
This posting and report is something I did when analyzing the amiss problem, and discovered a new diagnostic tool.
I redid the analysis today.
In effect the posting I made above regarding the report is relevant to the report and has nothing to do with the previous posting about the haywire behavior of my computer which seems strongly to be linked to a defective USB hub.
But thanks for noting my previous post anyway.
24 Nov 2010   #8
Brink
This report basically just lets you know what the USB device's power plan options are set as. I did not notice any issues in your report that were just normal for these devices though.
24 Nov 2010   #9
RJL24
Thanks for your analysis. if it ain't broke: don't fix it.
Cheers,
RJL
Driver power state failure crash-report included
Can someone tell me from the reports what and why I crashed??? Another BSOD! I was playing a game in Facebook, several windows open, but that's my usual! Windows 7 Pro, Service Pack 1, Chrome
BSOD Help and Support
Random reboot, windows 7 64 bit, SF Diagnostics report posted
Hi everyone, In the last week or so my PC randomly rebooted for no reason. I let it run to safe mode, rebooted again and all is fine. Not sure what it could be so I ran the diagnostics and I'm providing the results below. Thank you in advance, P.S. I don't run an antivirus but I do...
I'm such a ditz !! :o I've been jumping around too much trying to figure out some problems with my PC. Evidently I was referred to check something, then got interrupted & didn't follow through. (that's the way my days seem to be lately,too much going on at once). Anyway. . . was just looking for...
Performance & Maintenance
Hard Drive diagnostics report bad sectors
Hello, I am having serious corruption problems with my hard drive. I have reinstalled windows a few times now, but it always ends up being unable to boot. At the moment, my computer cannot even boot up in normal or safe mode, all my restore points have been deleted, and startup repair cannot do...
Problems generating a report with System diagnostics
Every time I run System Diagnostics it collects the data for 60 seconds and then I am asked do I want to open or save this file: report.html. If I save or open it I am greeted with a blank webpage saying navigation cancelled and the System diagnostic screen still says generating report ...
Software
