Windows 7 Forums Search
Windows 7 - MS-DOS Bootable Flash Drive - Create
12-14-2009   #19
Zidane24
How to Make a MS-DOS Bootable Flash Drive
06-06-2011   #20
chickenmatt5
Windows 7 Starter 32bit
Alright, I just wanted to make sure that the USB would not replace Windows 7.
I sure won't be doing anything to that degree. I'm assuming that MS-DOS running from a USB stick could see the C drive; is that correct?
06-06-2011   #21
Brink
Correct, it will be able to see any drive connected to the computer.
06-06-2011   #22
chickenmatt5
Thanks for the responses! Off to try MS-DOS, then.
06-06-2011   #23
Brink
You're welcome.
07-27-2011   #24
S4LTnL1ghT
Windows 7 Ultimate & Windows 8 v.7989
Getting this message when trying to boot from USB Key:
Remove disks or other media. Press any key to continue.
Any suggestions?
07-27-2011   #25
Bill2
Quote   Quote: Originally Posted by S4LTnL1ghT View Post
Any suggestions?
Either that key is not bootable or the machine is incapable of booting from a usb key.
07-27-2011   #26
Brink
Any suggestions?
It just depends on if your computer is capable of booting from a USB key or not, and if it's a bootable USB key or not as Bill posted above. If it's a newer model computer, then most likely it is able to.
My Gateway laptop does this to me. I have to keep tappping F8 at boot to open the boot menu, then select to boot from the USB key drive. You may have a different F key to press instead at boot to open the boot menu though depending on what brand your laptop or desktop is.
08-12-2011   #27
phlibby
Windows 7 Ultimate 32bit
I just followed the steps and it works great. The only thing I would warn people is it takes a lot of room. I used a 500Gig USB Portable drive and it used up 380Gig. I have tried all kinds of tools to retrieve the space back but I believe it will probably make 3 quarters of any drive you use unusable. Just keep this in mind and don't use a big drive like I did.
UPDATE:
I just tried it again and instead of using the Quick Format option I just left the box unchecked for that and it worked just fine. It did not take up a lot of room. Hardly any. Good to go - Thanks.
10-03-2011   #28
preiius
Windows 7 Professional 64bit
Sorry to dig up an old thread.
Why not use 'internal MS-DOS system files' in the HP utility?
10-07-2011   #29
TeeDoubleUDee
Windows Home Premium 64bit
Saved my bacon, AGAIN
Many thanks again to Brink. This tutorial helped me reflash the faulty F/W on Samsung 2Tb Spinpoint HDD.
Comment
 MS-DOS Bootable Flash Drive - Create problems?
Tutorial Tools
Similar Threads for: MS-DOS Bootable Flash Drive - Create
Windows 7 Tutorial Category
Win 7 X64 bootable flash drive General Discussion
Solved Problem with Bootable Flash Drive General Discussion
The Bootable Maintenance Flash Drive System Security
Creating a bootable flash drive from ISO file Installation & Setup
Returning bootable flash drive to normal? Hardware & Devices
