MS-DOS Bootable Flash Drive - Create
Page 3 of 6 FirstFirst 12345 ... LastLast
  1. Posts : 52
    Windows 7 Starter 32bit
       #20
    Alright, I just wanted to make sure that the USB would not replace Windows 7.
    I sure won't be doing anything to that degree. I'm assuming that MS-DOS running from a USB stick could see the C drive; is that correct?
  2. Posts : 72,043
       #21
    Correct, it will be able to see any drive connected to the computer.
  3. Posts : 52
       #22
    Thanks for the responses! Off to try MS-DOS, then.
  4. Posts : 72,043
       #23
    You're welcome. :)
  5. Posts : 1
    Windows 7 Ultimate & Windows 8 v.7989
       #24
    Getting this message when trying to boot from USB Key:
    Remove disks or other media. Press any key to continue.
    Any suggestions?
  6. Posts : 5,056
       #25
    Any suggestions?
    Either that key is not bootable or the machine is incapable of booting from a usb key.
  7. Posts : 72,043
       #26
    Any suggestions?
    It just depends on if your computer is capable of booting from a USB key or not, and if it's a bootable USB key or not as Bill posted above. If it's a newer model computer, then most likely it is able to.
    My Gateway laptop does this to me. I have to keep tappping F8 at boot to open the boot menu, then select to boot from the USB key drive. You may have a different F key to press instead at boot to open the boot menu though depending on what brand your laptop or desktop is.
  8. Posts : 4
    Windows 7 Ultimate 32bit
       #27
    I just followed the steps and it works great. The only thing I would warn people is it takes a lot of room. I used a 500Gig USB Portable drive and it used up 380Gig. I have tried all kinds of tools to retrieve the space back but I believe it will probably make 3 quarters of any drive you use unusable. Just keep this in mind and don't use a big drive like I did.
    UPDATE:
    I just tried it again and instead of using the Quick Format option I just left the box unchecked for that and it worked just fine. It did not take up a lot of room. Hardly any. Good to go - Thanks.
  9. Posts : 68
    Windows 7 Professional 64bit
       #28
    Sorry to dig up an old thread.
    Why not use 'internal MS-DOS system files' in the HP utility?
  10. Posts : 18
    Windows Home Premium 64bit
       #29
    Saved my bacon, AGAIN
    Many thanks again to Brink. This tutorial helped me reflash the faulty F/W on Samsung 2Tb Spinpoint HDD.
