Windows 7 Forums Search
Windows 7 - MS-DOS Bootable Flash Drive - Create
How to Make a MS-DOS Bootable Flash Drive
Published by Zidane24
12-14-2009
Default MS-DOS Bootable Flash Drive - Create
information   Information
This will show you how to create a flash drive that is able to boot your computer into a MS-DOS environment. This will be accomplished by using the HP Flash Utility and the Windows 98 MS-DOS System Files
warning   Warning
The flash drive being used in this process will be formatted. Please backup all of your data on the drive beforehand!
Here's How:
1. Download the HP Flash Utility hpflash1.zip and also download the Windows 98 MS-DOS System Files win98boot.zip. Extract hpflash1 to a location readily accessible
2. Run the installer and follow the simple on-screen instructions
3. Extract the contents of "win98boot" to a location readily accessible
4. Run the HP USB Disk Storage Format Tool that was just installed. Choose your flash drive from the drop down list at the top. Also make sure that the file system is set to FAT32.
5. Under Format Options tick the "Create a DOS startup disk" option. Click the "..." button near the empty text box to browse to the location of where you extracted the Windows 98 MS-DOS System Files (see step 3).
Tip   Tip
Tick "Quick Format" under Format Options to speed the process up (if you don't want a comprehensive format). You may also want to give the drive a label by typing one in the Volume Label text field
6. Click the "Start" button.
warning   Warning
After you click the "Start" button , you will be given one final prompt that warns you that the flash drive selected will be formatted. This is your last chance to backup data on the drive; after you click yes it will be too late
Tip   Tip
You may remove the files extracted from the archive "win98boot", they are not needed anymore
Frequently Asked Questions
Q: Why would a MS-DOS USB Drive be useful today? Wasn't that included in older Operating Systems?
A: MS-DOS was the underlying layer of the Windows 9x series of Operating Systems (Windows 1-ME) that was the "functionality" of the system. A MS-DOS bootable disc can be used to run many recovery tools (still used today) and also update the BIOS of the computer. If you are running an x64 system with no floppy drive and a manufactuer who only provides a 16-bit BIOS updater, this method is the only way to update your BIOS.
Q: I checked my flash drive after applying the steps above and it is empty? What gives?!
A: Unless the option to show protected operating system files is checked in folder options, Windows will hide these files due to their attributes matching that of system files. Don't worry, the relevant files are still there
Q: Alright I successfully completed the steps above, now what do I do?
A: Now you can download the tool you wanted to run (such as CHKDSK) or your BIOS update application (from the manufactuer) and place the files on to the root of the flash drive. You can find most tools by doing a simple google search
Tip   Tip
The Windows 98 MS-DOS System Files archive (win98boot) above has some system tools already included (ex. FORMAT, FDISK, SYS). Just drag and drop these files onto your flash drive
Q: My flash drive has been converted to the MS-DOS System Disc and I have some tools/BIOS revisions on the drive as well, how do I boot up MS-DOS?
A: This will largely depend on your model of computer but you will need to restart you computer with the flash drive plugged in and boot to the drive by means of a boot menu or by modifying your BIOS to boot to the flash drive first. Consult the manual of your computer or the respective manufactuer's website for further details.
Q: I have no further need for the MS-DOS System Disc, how can I remove it from my flash drive?
A: You may format the flash drive with the built in Windows format utility or you may format it by using the HP USB Disk Storage Format Tool that was used above.
Hope it helps,
Chris
Resident Linux Expert
Zidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond reputeZidane24 has a reputation beyond repute
Tutorial Tools
12-19-2009   #1
DocBrown
Xp Pro SP3 x64, Win7 x86 (Ult 7600), Win7 x64 Ult 7600, TechNet RTM on AMD x64 (2.8Ghz)
I have a Dos Boot CD, but this sounds great. I will have to try this Science Experiment on some of my "Dinosaur" computers
" Doc "
12-22-2009   #2
Dave76
Windows 7 Ult x64 - SP1/ Windows 8 Dev Build x64
Nice tut, thanks for the info, this will be handy
12-22-2009   #3
eegleye
Windows 7 64 Home Premium
Windows 7 shows Error, Device media is write-protected. But it isn't. Using a 4 gig Patriot flash drive. Help!
12-22-2009   #4
Zidane24
Quote   Quote: Originally Posted by eegleye View Post
Huh...write-protected...
Was the drive involved in any activity besides being used for the tutorial when the error occurred?
Try restarting the computer and thn try again...
12-23-2009   #5
eegleye
USB Flash drive bootable
Never got the Patriot 4 gig to work...always "write protected". I can write to this chip otherwise.
Tried an HP 8 gig and a 16 meg SD chip and they both worked OK. Something to do with this particular Flash drive.
01-02-2010   #6
gregrocker
Win7 x 6 PC's
Thank you for finally showing me how to use that HP tool. I knew it would be useful for something.
Little did I know I could have copied many apps like memtest and gwscan right in on top of Win98 DOS hidden files.
I wonder if they can then be deleted and replaced with another DOS app without wrecking the formatting?
This is a great find. Kudos
03-15-2010   #7
lkiamd
This is simple, and I got it ,thanks.
03-15-2010   #8
roboticus
xp pro
Thank you very much. This guide was a big help setting up win7 with no floppy drive.
05-11-2010   #9
Everlong
Windows 7 Enterprise x64 Service Pack 1
This tutorial looks familiar DOS USB boot drive - Vista Forums
Just kidding, good job. Was wondering if there was something like this on here.
Comment
MS-DOS Bootable Flash Drive - Create problems?
Tutorial Tools
Similar Threads for: MS-DOS Bootable Flash Drive - Create
Windows 7 Tutorial Category
The Bootable Maintenance Flash Drive System Security
System Image recovery from bootable WinPE flash/usb drive. Backup and Restore
Creating a bootable flash drive from ISO file Installation & Setup
Create bootable USB drive for Windows 7 x64 on a x86 machine Installation & Setup
Returning bootable flash drive to normal? Hardware & Devices
