Windows 7: System Restore Point Shortcut
13 Nov 2008   #99
Brink
64-bit Windows 7 Ultimate SP1 & Windows 8 Enterprise
Texas
How to Make a "Create System Restore Point" Shortcut in XP, Vista, Windows 7, and Windows 8
02 Jul 2012   #100
Brink
Texas
Quote   Quote: Originally Posted by ferreel View Post
I have tried to do the shortcut both with and without the success message and I get the error message:
For shortcut with success message)
Can't find script engine "VBScript" "C:\Program Files\Restore Point Shortcut\CreateRP-Success_Message.vbs".
For shortcut w/o success message)
Can't find script engine "VBScript" "C:\Program Files\Restore Point Shortcut\CreateRP.vbs".
Please let me know if you have any ideas.
Hello Ferreel, and welcome to Seven Forums.
It sounds like you missed doing steps 7-11 to place the extracted folder with the .vbs file at the location in your post.
02 Jul 2012   #101
ferreel
Windows 7, 64 bit
Shawn,
Thanks, but I did copy it over. I do have the feeling that I may be overlooking something simple though. I have attached a screenshot of my error.
03 Jul 2012   #102
Brink
Texas
It looks like it can't find the vbscript file. Double check to make sure that you have these files below.
C:\Windows\System32\vbscript.dll
and
C:\Windows\System32\wscript.exe
As a test, download and merge the vbs option in the tutorial below to restore it's default associations to see if that gets rid of the error for you afterwards.
04 Jul 2012   #103
ferreel
Windows 7, 64 bit
Shawn,
I have both the vbscript.dll and wscript.exe files. I also downloaded and merged the vbs option in the tutorial and restarted my computer but still got the same error.
04 Jul 2012   #104
Brink
Texas
Ferreel,
Double check the registry location below to see if you have the same path set for (Default). If you need help with the registry, then please let me know before proceeding.
04 Jul 2012   #105
ferreel
Windows 7, 64 bit
Shawn,
It appears my default is referencing the wrong location, could this be the issue?
04 Jul 2012   #106
Brink
Texas
Yep, it looks like McAfee messed with it. If you like, download and merge the REG file I attached below. It will change the path in the registry to what it should be by default. If you get an error that part of the REG file couldn't be merged, then you will need to take ownership of the InprocServer32 key using step 3 in OPTION THREE of the tutorial below first, then merge the REG file again.
Take Ownership of file - Vista Forums
When finished, hopefully the shortcut will run without getting that error anymore.
File Type: reg restore_vbscript.dll.reg (380 Bytes, 14 views)
04 Jul 2012   #107
ferreel
Windows 7, 64 bit
Shawn,
That did the trick! I actually just gave User and Administrators full control in permissions for the InprocServer32 key.
Thanks for all of your help! I would have never figured this out by myself.
05 Jul 2012   #108
Brink
Texas
You're most welcome Ferreel. I'm happy to hear it's working for you now.
03 Jan 2013   #109
Brink
Texas
Tutorial updated to work with Windows 8 now.
Comment
 System Restore Point Shortcut problems?
Tutorial Tools
Similar help and support threads for: System Restore Point Shortcut
Windows 7 Tutorial Category
Solved Shortcut to create a restore point? Backup and Restore
System Restore how to set to show every past restore point inc/manual General Discussion
System Restore- restore point creation error Backup and Restore
Shortcut to Create Restore Point Backup and Restore
create restore point... shortcut? System Security
