Windows 7: System Restore Point Shortcut
18 Apr 2016   #180
Brink
64-bit Windows 10 Pro
Quote   Quote: Originally Posted by jdUnionngaden View Post
Good morning All! ... Shawn Brink (?)
I've been using Shawn's Restore Point script for 4+ years on Windows 7. Has someone written one for Windows 10?
Thanks in advance for your assistance!
Best,
/jdU
Hello jdU,
I sure have. Here you go.
System Restore Point shortcut - Create in Windows 10 - Windows 10 Forums
18 Apr 2016   #181
jdUnionngaden
Windows 7 Pro 64bit
Great!
Just what I need!
I'm about to upgrade from Win7 Pro ... not too happy to learn all updates will be automatic as I like to handle that task myself: read, review and check on success, etc. Then run the Restore Point so I don't have to worry about restoring to a point before the last update(s).
Thanks again, much appreciation!
/jdU
18 Apr 2016   #182
Brink
You're welcome.
Automatic updates can be handled in Windows 10 as well though.
Windows Update Automatic Updates - Enable or Disable in Windows 10 - Windows 10 Forums
18 Apr 2016   #183
jdUnionngaden
Windows 7 Pro 64bit
Thanks again
18 Apr 2016   #184
Brink
Comment
Tutorial Tools
Windows 7 Tutorial Category
Shortcut to create a restore point?
I would like a shortcut or a hot-key on my G15 keyboard to MAKE a system restore point, as I think the way to come to the window where the "make point"-button is, is way to long. But I can't get it to work :cry:. I think I have read about it in this forum earlier, but I have tried to search the...
Backup and Restore
Can System Restore Automatically Generate Daily Restore Point?
I used to be able to get a System Restore point generated daily and accessible on a calendar. I understand that the Restore Point calendar has been done away with, can't imagine why? Is it now possible to have a daily System Restore point automatically generated and easily accessible somewhere?...
Backup and Restore
Windows 7 system restore point. Can't create / restore .
Hi Ok I borke world recored for formating windows 7 , the last 2 months . The problem is ; Windows System restore keep freezing , I'm not trying to do system restore , but when I try to install/remove a software , windows try to create restore point , making the installation/removing...
Backup and Restore
System Restore how to set to show every past restore point inc/manual
I am having difficulties with this. 1. Does Win 7 limit the quantity of past restore points it shows upon user request? 2. If stored elsewhere where do I find them? 3. Is there a way to set it up to show at least the last 10 restore pointsd created, or is there a smaller limit. Right now the...
General Discussion
Shortcut to Create Restore Point
Hello all: I just migrated from XP to Win7 and am trying to get used to the changes. In XP I had a shortcut in my start menu that took me to the System Restore app. In XP this app covered both creating a restore point and performing an actual restore. In Win7 they are separate. The shortcut info...
Backup and Restore
create restore point... shortcut?
Since this is a beta and installing/testing alot of programs/drivers there is a need for restore points. Am wondering if there is a way to create a shortcut str8 to the dialogue box of naming the restore point with the create button... rather than pulling up the properties of system restore. To...
System Security
