Icon Cache - Rebuild
Page 5 of 31 FirstFirst ... 3456715 ... LastLast
  1. Posts : 72,052
       #40
    PvtMatter,
    With all of the different issues you are having, you might consider backing up anything that you do not want to lose while in Safe Mode, then do a clean reinstall of Windows 7.
  2. Posts : 62
    icons
    Shawn:
    before I do a reinstall can I delete all user accounts except the original one I had, Larrry-PC\Administrator and try that?
  3. Posts : 72,052
       #42
    If you have access to the Larry-PC account, then sure you can delete the other accounts while logged in the Larry-PC account if you like. Hopefully that will work for you.
  4. Posts : 146
    Windows 8.1 Pro 64-Bit
       #43
    Thank you thank you thank you!!!!!!!!!
    Just fixed my problem!!
  5. Posts : 72,052
       #44
    You're most welcome BDani. :)
  6. Posts : 49
    Windows 7 Ultimate 32bit
       #45
    Great tutorial. Thanks a lot.
  7. Posts : 3,612
       #46
    hope you dont mind me posting this here brink i found a program **Rebuild Icon Cache version 0.7b** that does the same as your tutorial see what you think http://screeny05.deviantart.com/art/...0-7b-164152806
  8. Posts : 72,052
       #47
    No problem Brian. :)
  9. Posts : 4
    System is in danger.
    After the last step of restart, all of my computer's icons have been gone.Help me.There are no icons.Even, start menu isn't opening.
  10. Posts : 3,612
       #49
    try this program i posted **Rebuild Icon Cache version 0.7b**
    Rebuild Icon Cache v0.7b by ~screeny05 on deviantART
