Windows 7: Hardware System Properties Shortcut - Create
How to Create a Windows 7 Hardware System Properties Shortcut
Published 31 Dec 2009
Featured Tutorial
Windows 7 Installation - Transfer to a New Computer
How to Transfer your Complete Windows 7 Installation to a New Computer
Microsoft Account Primary Alias Email Address - Change
How to Change your Microsoft Account Primary Alias Email Address
Safe Internet Browsing
How to safely operate on the internet and stay free from malware infections
Screen Capture and Video Editing in High Quality
Search - Find More with Filters and Operators
How to Use Windows Search Filters and Operators to get better Search Results in Windows 7
Microsoft Account Display Name - Change
How to Change your Microsoft Account Display Name
information   Information
This will show you how to create or download a Hardware System Properties shortcut that opens directly to the Hardware tab in System Properties. You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
warning   Warning
You must be logged on as an administrator to make changes to the settings using this shortcut.
EXAMPLE: Hardware System Properties
OPTION ONE
Download the Shortcut
1. Click on the Download button below to download the file below.
Hardware_System_Properties .zip
download
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the Hardware System Properties shortcut to the desktop.
4. Right click on the Hardware System Properties shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
Manually Create the Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut. (See screenshot below)
2. Copy and paste the location below into the location area, and click on the Next button. (See screenshot below)
C:\Windows\System32\SystemPropertiesHardware.exe
3. Type Hardware System Properties for the name, and click on the Finish button. (See screenshot below)
4. Move the shortcut to where you like for easy use.
Need more help? Try searching our extensive help and support site.
Loading
Comment
 Hardware System Properties Shortcut - Create problems?
Tutorial Tools
Similar help and support threads for: Hardware System Properties Shortcut - Create
Windows 7 Tutorial Category
Keyboard Properties Shortcut - Create Tutorials
System Protection Properties Shortcut - Create Tutorials
DEP System Properties Shortcut - Create Tutorials
Remote System Properties Shortcut - Create Tutorials
Computer Name Properties Shortcut - Create Tutorials
