Windows 7 - System Protection Properties Shortcut - Create
How to Create a Windows 7 System Protection Properties Shortcut
Published by Brink
12-31-2009
This will show you how to create or download a System Protection Properties shortcut that opens directly to the System Protection tab in System Properties. You can also Pin to Taskbar or Pin to Start Menu this shortcut, or move where you like in Windows 7 for easy use.
Warning
You must be logged on as an administrator to make changes to the settings using this shortcut.
EXAMPLE: System Protection Properties
OPTION ONE
Download the Shortcut
1. Click on the download button below to download the file below.
System_Protection_Properties.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract the System Protection Properties shortcut to the desktop.
4. Right click on the System Protection Properties shortcut, and click on Properties, General tab, and on the Unblock button. (See screenshot below) NOTE:If you do not have a Unblock button under the General tab, then the shortcut is already unblocked and you can continue on to step 5.
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file on the desktop if you like, or save it to use again.
OPTION TWO
Manually Create the Shortcut
1. Right click on a empty area on desktop, and click on New and Shortcut. (See screenshot below)
2. Copy and paste the location below into the location area, and click on the Next button. (See screenshot below)
3. Type System Protection Properties for the name, and click on the Finish button. (See screenshot below) NOTE:You can name this anything you would like though.
4. Move the shortcut to where you like for easy use.
