Page 21 of 33 FirstFirst ... 11192021222331 ... LastLast
  1. Posts : 21,004
       #200
    As Brink says mate and it depends on the machine too I found my laptop with dual cores a lot slower than the quad cores of the desktops. That is not to mention what clock speed they run at too.
  2. Posts : 161
    Windows 7 Home Premium 64 bit
       #201
    Shawn,
    My Win 7 HDD contains the automatic Windows 7 install with 2 partitions, System Reserved and a "C" partition.
    After reading the thread (great stuff :) ), I have a couple of questions about the "clean" and "clean all" commands:
    - Does the "clean" command accomplish the same thing as deleting both partitions from the Disk Management Console, with the addition of deleting the MBR when using the "clean" command? I'm guessing that partition-deletes from the Console won't delete the MBR since it's located prior to the beginning of the first partition, the System Reserved partition.
    - Does the "clean all" command unhide and overwrite any "Host Protected Area" sectors, more known as the HPA? Those are typically located after the last user partition on a HDD, for those HDD's the contain a HPA.
    After reading some articles about HPA's, it would appear that one would need to "unhide" the HPA before most disk-wipe tools can access that area to overwrite any data located within the HPA.
    Seatools (Dos) and "HDDErase" will unhide the HPA but "DBAN" doesn't access that area according to the DBAN's site FAQ section.
    I think there is a Linux command that will unhide the HPA but I don't recall that command at present.
  3. Posts : 72,052
       #202
    Hey Scoop, :)
    "Clean" and "Clean all" both will completely wipe the hard drive of all partitions hidden or not.
    The only difference between them is that "Clean all" includes a 1 pass override secure erase, and "Clean" doesn't.
  4. Posts : 161
       #203
    Brink said:
    Hey Scoop, :)
    10-4, thanks :). You just saved me a couple of steps during my periodic "pre-cloning" routine :).
  5. Posts : 72,052
       #204
    You're welcome. Yeah, unless you just need to do a secure erase, I would use "clean" to save time.
  6. Posts : 161
       #205
    Yes. I usually do a "pre-cloning" delete of partitions, only to make it easier for me to identify the Target HDD within cloning software since it will appear as unallocated. This command saves me some "clicks" and steps :)
  7. Posts : 1
    Clean all, clean, etc doesn't work. Prompt says Clean not allowed.
    Thank you Shawn - I followed the excellent directions but get the following errors (snip below)
    "Virtual Disk Service Error: Clean is not allowed on the disk containing the current boot, system, pagefile, crashdump or hibernation volume." note that I am not trying to format the OS drive, just a HDD that was originally in a raid configuration with another identical drive that I formatted & accidentally made Virtual. Now I just want to get it back to mirroring it's twin again. Can anyone help?
    Thank you!
    Attached Thumbnails Attached Thumbnails Disk - Clean and Clean All with Diskpart Command-error-snip.png
  8. Posts : 72,052
       #207
    Hello Mac, and welcome to Seven Forums.
    See if running the "clean" command at boot instead may allow you to do so. :)
  9. Posts : 2
    64
       #208
    I'm use to clean command when install window. Pls help me recover data. Thank all very much (
  10. Posts : 72,052
       #209
    Hello tinhdx, and welcome to Seven Forums.
    Unfortunately, there is no recovery when you use the clean command to wipe a hard drive unless you have a backup or system image saved at another location.
