Microsoft Mangement Console - Create Custom MSC
How to Create a Custom MSC in Microsoft Management Console in Windows
This will show you how to add MSC snap-ins of your choice (ex: gpedit.msc and compmgmt.msc) in the Microsoft Management Console to then save it as a custom MSC file to always open this file with the added snap-ins included in Vista, Windows 7, and Windows 8.
You can place this custom.msc file where you like for easy use, or create a shortcut of the custom.msc file (if saved at C:\Windows\System32) to use the shortcut where you like instead.
The settings below will be remembered when you save your custom MSC console, and each time you close it afterwards.
  • Column widths
  • Action pane (off/on)
  • Default opening location/position
  • Window size
If you decide you do not want the custom MSC file you created using this tutorial at a later date, then you can always just delete it like any other file without any problems doing so.
EXAMPLE: Custom MSC File
NOTE: For example, I created a custom MSC file that has the gpedit.msc (Local Group Policy Object Editor) and compmgmt.msc (Computer Management) snap-in added in one MSC console. The custom MSC file will open with these two snap-ins, or the ones you added, always included. Step5.jpg
Here's How: 1. Press the Windows + R keys to open the Run dialog, type mmc in the search box, and press Enter.
2. Click/tap on File (menu bar) and Add/Remove Snap-in. (see screenshot below) Step1.jpg
3. In the left pane, select the msc snap-in (ex: Computer Management) you want to add, and click on the Add button in the middle. (see screenshot below) Step2.jpg
4. If you get option dialog windows for the snap-in, then you can set them to how you like, and click/tap on Next, OK, or Finish until finished. (see screenshots below)
NOTE: Each snap-in will have it's own set of options. Step3.jpg
5. Repeat steps 3 and 4 until you added all of the snap-ins that you want in the right pane for this custom MSC file. For example, I wanted to add gpedit.msc (Group Policy Object Editor) as well. (see screenshot below) Step4.jpg
6. When done, click/tap on OK. (see screenshot above)
7. Click/tap on File (menu bar) and Save As. (see screenshot below) Step6.jpg
8. Navigate to where you want to save this custom .msc file to, type in a name for it, and click/tap on Save. (see screenshot below) Step7.jpg
9. You now have a custom MSC file that you can click on to always open a management console with the snap-ins you added for it. Move it to where you like for easy use.
NOTE: You could also Pin to Taskbar or Pin to Start Menu this MSC file.
W7 Ultimate SP1, LM19.2 MATE, W10 Home 1703, ...AMD Phenom II x6 1100T, 3.3 GHz12GB DDR3 1333 G-Skill (4GB x 2), G-Skill (2G...NVIDIA GeForce GTX 660
n/a
ASUS M4A88T-M/USB3 (AM3)
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
3x Antec TRICOOL 120mm Fans
Wired Optical
DSL
Pale Moon (64 bit)
2018-12-27 Upgraded HDDs
Thank you Lehnerus. Added. It also remembers them for when last closed as well. :)
No problems (and thank you for writing so many good tutorials in the first place). :)
It just came up on mickey megabyte's thread and when I checked to see if I needed to write a tutorial, I found your one.
It's easy to forget a small detail (or two) when writing instructions.
Although I have only posted 2 (official) tutorials, I am still paranoid that I've forgotten something important/obvious. :(
Until I authored mine ("Computer Management") it would always start with the Action pane on and at a small size (i.e. it never remembered how I left it).
n/a
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
Wired Optical
DSL
Pale Moon (64 bit)
Strange. I created a Computer Management MSC and saved it to the desktop. Each time I open the custom MSC, make changes to it's size, position, etc... and closed it, it would open the same way next time. At least for me it does. :confused:
it doesn't for me - it opens at the size it was at the last save.
but then again, mine are mucked up somehow anyway! :)
ultimate 64 sp1i5 2500K [email protected]8 gigs GSkill Ripjaws 1600amd hd6950
mickey megabyte 1234
ultimate 64 sp1
MSI P67A-GD53
amd hd6950
creative x-fi gamer
samsung 24"
antec 550
antec three hundred
i'm a cooling fan
saitek eclipse ii
logitech g3
about 4 Mbps
i love win7
It is weird
I meant the default "Computer Management" console.
Unless I choose "Author", I don't get the "Save" option.
Even using "Author" mine won't remember to open showing "Services".
It will remember other choices that I've tried.
I have mine set to open to "Device Manager" instead.
Note:
I haven't tried every possible option though.
I guess it's just like how some people have trouble with certain programs and others don't (e.g. AV programs, Firefox, etc.).
I guess some weird combination of settings and/or software is responsible. :confused:
n/a
Realtek?
Samsung S23B350
Cooler Master
Antec GX300 Tower
Wired Optical
DSL
Pale Moon (64 bit)
Ah, ok. I get the same as you with that as well. It's only when I create a custom MSC from the tutorial for it when it is remembered.
I've never had "Author" do anything different for me though.
