Start Menu - Pin or Unpin a Folder, Drive, and Library
Page 1 of 4 123 ... LastLast
    Add or Remove "Pin to Start Menu" for a Folder, Drive, and Library in Windows 7
    By default, you can only pin programs to the Start menu in Windows 7 with the Pin to Start Menu context menu item. You could also drag a folder, drive, or library to the Start button until you see Pin to Start Menu and drop it to pin the folder, drive, or library to the Start Menu.
    This will show you how to add Pin to Start Menu to the context menu of a folder, drive, or library for all users in Windows 7.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    From the Start menu All Programs area, you can only pin the folders you have added to All Programs and not any of the default Accessories, Administrative Tools, Maintenance, and Startup folders.
    You can pin any folder, drive, or library from within Windows Explorer to the Start Menu.
    EXAMPLE: "Pin to Start Menu" Enabled for Folders and Drives
    NOTE: You will need to press and hold Shift and right click on a folder or drive to see Pin to Start Menu.
    Start Menu - Pin or Unpin a Folder, Drive, and Library-folder.jpgStart Menu - Pin or Unpin a Folder, Drive, and Library-folder2.jpg
    Start Menu - Pin or Unpin a Folder, Drive, and Library-drive-1.jpgStart Menu - Pin or Unpin a Folder, Drive, and Library-drive-2.jpg
    EXAMPLE: "Pin to Start Menu" Enabled for Libraries
    NOTE: You will just need to right click on a library to see Pin to Start Menu.
    Start Menu - Pin or Unpin a Folder, Drive, and Library-library-1.jpgStart Menu - Pin or Unpin a Folder, Drive, and Library-library-2.jpg
    Here's How:
    1. To Enable Folder, Drive, and Library "Pin to Start Menu"
    Enable_Folder_Drive_Library_Pin_to_Start_Menu.reg
    B) Go to step 3.
    2. To Disable Folder, Drive, and Library "Pin to Start Menu"
    Disable_Folder_Drive_Library_Pin_to_Start_Menu.reg
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
  1. Posts : 2
    Issue with unpinning a library
    I pinned a custom library (named Downloads) to the Start Menu without downloading the registry entries found in this thread. The problem was, I was unable to unpin the item from the Start Menu. Whenever I right clicked on it, I would get two options, open or properties. I tried deleting the library. Not only did the Start Menu entry not go away, but now when I right clicked and selected properties, I was informed the item did not exist. Still no option to unpin though, even for a non-existent item. So I went googling. With the enable registry keys provided here the issue was corrected. So this is more of an FYI, if this is released without those registry keys, then the custom libraries will need to be prevented from being pinned to the Start Menu.
  2. Posts : 72,037
    Thank you Darius, and welcome to Seven Forums.
    Interesting, I'm curious as to how you managed to pin the folder to the Start Menu without these registry entries though?
  3. Posts : 2
    Thanks. Well as to that, I didn't know about these registry entries, so I went looking for a solution myself. I'm a tinkerer at heart, so I tried a number of ways to get it to pin in place. The method that worked was to create a custom library, use the context menu to create a desktop shortcut, then pin the shortcut to the start menu. Then I deleted the shortcut and everything worked as intended. At least for 2 days until I decided I did not really want a downloads link on my start menu after all. What I really wanted was the ability to add it to the list of libraries on the right side of the menu. Haven't quite figured that one out yet
    After a little more poking around, this works without the custom library. To pin any library to your start menu, you can simply create a desktop shortcut, then drag that to the start menu to pin it. You just can't unpin it.
  4. Posts : 72,037
    Using this tutorial, you should be able to just right click on any library in the Libray folder and click on Pin to Start Menu to do so instead, and Unpin from Start Menu to remove it.
  5. Posts : 1
    Hi!
    We can just drag folder from anywhere to start menu and pin...
  6. Posts : 72,037
    Hello Bob, and welcome to Seven Forums.
    Yes, thank you that is true, but this will add the Pin to Start Menu option to the folder or library context menu so that you can also have it as an option to use to pin a folder or library to the Start Menu as well. Either way is good though. :)
  7. Posts : 2
    Windows 7 x64 RC
    Hello,
    How did you find out what GUID needed to be edited (in the .reg file)?
  8. Posts : 72,037
    Hello Whattf, and welcome to Seven Forums.
    Going through the GUIDs in the HKEY_CLASSES_ROOT\CLSID keys, most of them will have a description that will help ID what the GUID is for. From there it's just a matter of looking for that GUID in the usual context menu registry locations.
  9. JQQ
    Win7
    Pin any folder, document, shortcut to Main Start Menu
    Brink: your Enable_Start_Menu_Pin_Folder enables documents or shortcuts (as well as folders) to be (Shift-rtClick) to main Start Menu. However, this will not work if shortcut points to file on another network machine (Vista & XP of course allowed this by simply dropping shortcuts into the StartMenu folder - but not on Win7; it must be pinned). Is the problem some arcane security setting (maybe this post holds the key Help Classic Menu - Shortcuts attributes - BIG mistake )?
