File Extension Icon - Change Default Icon
Page 2 of 8 FirstFirst 1234 ... LastLast
  1. Posts : 72,058
    You're welcome Pajolool. :)
  2. xTL
    Thx alot Brink :)
    Is there a tut for .avi .mkv .wmv .mp4 .mov and other media file formats like that?
    i have been searching for it but without success, coz my current one has the ugly vlc icon on em, not very fond of the icons in vlc, but i love the program itself :)
  3. Posts : 72,058
       #12
    Hello xTL,
    You can use this tutorial for them as well. Just substitute .mp3 for the other file extensions in either step 3 or 4 based on what you have as the file extension's default program. :)
  4. xTL
    Hi Brink thanks for the reply, yea i figured that much hehe, i saw em close to the .mp3 that i changed, just wanted to check with yah if you had created another tut for em.
    Thx man :)
  5. xTL
    hmm, im using a 3rd Party Program as the Default Program to open my movies ( VLC ) so i navigate here: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.avi\UserChoice
    planing on using my own .ico ( have the location )
    i don't get where i change the default location for the icon.
    Advice please :/
  6. Posts : 72,058
       #15
    In the right pane of UserChoice, what do you have as the data for Progid (step 4B)? This is were you will need to go to (steps 5 to 8) to change the icon path at.
  7. xTL
    thx brink :) ill continue tomorrow :)
    i have to get up early =(
  8. Posts : 72,058
       #17
    Ok mate. I'll see you then. :)
  9. Posts : 2
    windows 7 home premium 64 bit
       #18
    there is no icon tab
    Brink, when I right click imageres.dll, and click properties, there is no icon tab. I have downloaded and installed Iconviewer program. What's wrong? I use win 7 home permium 64 bit. Thanx
  10. Posts : 2
       #19
    problem solved. turns out I must install the 64 bit version. my bad
