Windows 7: System Restore General Troubleshooting to Fix Issues
Published by Capt.Jack Sparrow
23 Jan 2010
General Troubleshooting to Fix System Restore Issues
information   Information
If the System is not able to create System restore point try to Create the restore point manually. If you are unable to create a system restore point manually then you could try these steps
1. Make sure that System Restore is enabled
2. Make sure that you have sufficient disk space on all the drives where System Restore is enabled
3. Try creating a System Restore point manually and making a note of the Error Message you get. If you don't get one, check if one has been created or not.
4. Next set would be to Check the Event Viewer
Type Event Viewer in Start Menu Search Box, hit Enter. Expand Windows Logs then click on Application. Look for Errors if your find any codes post it here or search in Google for that Error codes.
5. Type Services in Start Menu Search Box, hit Enter. Make sure that the Volume Shadow Copy Service is Running if its not running then double click on it.
  • If the Start up type is set to Disabled or Manually
  • click the Drop down and Select to Automatic and click on start
  • Apply it then Click OK
6. Also make sure RPC, Task Scheduler and all service related to DCOM is started
7. Next step we could try to Rebuild the WMI components
  • Close all open programs.
  • Download the WMI.bat from from here
  • Right Click on WMI.bat file and Run as administrator.
  • The Command Prompt window will open. When prompted, type Y to continue.
  • Allow the Command Prompt to finish and automatically close.
8. Then next step would be to try to create the Restore point in Selective Startup
9. Try to Login under Safe Mode then try to Create a restore point
10. Try to Turn off the System Restore and turn it back on
11. Remove restore points:
  • In Computer (Computer), right-click on C, then Properties (properties), click Disk Cleanup (Disk Cleanup), then clean the system files (Clean up system files)
  • which shows the More Options tab (More Options)
  • By clicking on Clean (Clean up) under System Restore and Shadow (System Restore and Shadow Copies), restore points will be removed, except the most recent.
12. Run System File Checker
  • Start type cmd then Right Click and Run as administrator
  • Type in SFC/ SCANNOW
13. If that also didn’t fix then the next option would be to perform Repair Install
Captain
11 Mar 2010   #1
Bare Foot Kid
Microsoft MVP
W 7 64-bit Ultimate
Geez Cap'n, I could've used this earlier today, let me see if I can find the thread.
23 Aug 2010   #2
marianacnt
windows 7
Hy!!!
I think I tried all of those things and it still doesn't work... I have the same problem. The restore points desappear when I reboot... Any other ideas? Thank you
23 Aug 2010   #3
karlsnooks
Excellent tutorial. Thanks.
23 Aug 2010   #4
Capt.Jack Sparrow
Quote   Quote: Originally Posted by marianacnt View Post
Hy!!!
Did you try that last step ? Repair install ?
23 Aug 2010   #5
Capt.Jack Sparrow
Quote   Quote: Originally Posted by karlsnooks View Post
Thanks Karl and Thanks for the Rep
23 Aug 2010   #6
marianacnt
windows 7
I haven't tried it yet the repair install... I'm afraid I will have to reinstall many things... I'm not sure what will it be and if I still have all the needed drivers...
23 Aug 2010   #7
Capt.Jack Sparrow
No you don't have to reinstall every single thing. Go through the tutorial link i mentioned.
22 Dec 2010   #8
Borg 386
Got a question, sys rest won't work since an update got "stuck", anything in your arsenal to clean out, reset or reinstall Windows Update agent short of a Repair install?
05 Jan 2011   #9
chriswchrisw
Win 7 Home Prem 64
G'day, mate....If I delete SR points as described in your para 11, they all delete (as advertised) except for the System Image Restore Points. How do I get rid of them?
Comment
Tutorial Tools
Windows 7 Tutorial Category
SF IE Restorator - Troubleshooting General Issues with IE
SF IE Restorator - Troubleshooting General Issues with Internet Explorer This is small utility for Troubleshooting Internet Explorer issues. It will Flush DNS, Re-register concern dlls for Internet Explorer (3 different types 64-Bit, 32 Bit on 64-Bit OS and 32-Bit) Reset IE to Default settings,...
Tutorials
Can I Restore A HDD System Image To A SSD Without Issues?
Can I Restore a System Image of a HDD (70 Gb of 500Gb used) => To a 256 Gb SSD? What about any required SSD drivers and/or any SSD management software that won't be on the HDD System Image? Anything else that may affect a successful drive swap from HDD to SSD?
Backup and Restore
System Restore and Windows Update issues--related?
I am using Windows 7 Pro 64 bit and I recently noticed that I can no longer restore to any of my older SR points. I can manually create one and restore to that but nothing else works. It even fails in Safe Mode. At the same time I notice I am no longer able to check for or download updates. I've...
Backup and Restore
Outlook - General Troubleshooting Guide for Issues
General Troubleshooting Guide For Issues with Microsoft Outlook These are some General troubleshooting steps to fix Outlook issues like unable to open or crashing while doing something in Outlook etc. 1. Start up problem of Outlook This is one of the most common problems with...
Tutorials
General Troubleshooting to Fix WMP Issues
Windows 7 has some fine in-built diagnostic tools to help you trouble-shoot Windows Media Player issues, which you may be facing. To open these specific troubleshooting & diagnostic modules do the following: Type msdt.exe -id WindowsMediaPlayerConfigurationDiagnostic in Start Search...
Music, Pictures & Video
When trying to restore my system (had some buggy issues), I get the following message: "System Restore did not complete successfully. Your computer's system files and settings were not changed. Details: System Restore failed to replace the file (C:\Windows) with its original copy from the...
Backup and Restore
