Windows 7: Display Color Calibration
28 Oct 2012   #70
TheKloowner
Quote   Quote: Originally Posted by Brink View Post
I'm afraid that I don't know what else to try other than adjusting the color settings on the monitor itself.
No problem, thanks.
30 May 2015   #71
drugo
windows 7 ultimate 64bit
hi
yesterday i used a software to calibrate my monitor and x-rite photo calibrator and when i uninstalled it , it did a mess up
are there default screenshots about windows 7 Color Management ?
i did a mess up even on my windows 8.1 , but i guess the default are the same
thanks
30 May 2015   #72
Brink
64-bit Windows 10 Pro
Hello Drugo,
If you like, you should be able to run the Display Color Calibration in Windows to see if it may be able to correct it for you.
30 May 2015   #73
drugo
Hello Drugo,
Hi Brink
but the hardware system is really more accurate then the display color calibration in windows
i 'm looking for default settings of windows 7 color management (a clean install), like this (but i don't think they are default the screenshot) above
http://www.timelessme.com/temp/posti...n7Issue_01.jpg
thanks
30 May 2015   #74
Brink
The default is based off of your monitor and graphics card, so it will not always be the same from system to system. About all you can do is run the calibration again until you have it set how you like.
Doing a system restore using a restore point dated before you did the calibration will undo it for you though.
Display Color Calibration ALWAYS resets?! Please Help!
Hi, I recently got windows 7 for my desktop, and I have this 22'' monitor which looks really nice when properly calibrated (gamma, reds, etc). My problem is that every time I do a calibration, and let the computer either go to sleep, lock, turn off, the calibration resets to this ugly looking...
Graphic Cards
Color profiles calibration?
I'm setting up a new install of Win 7 Professional, the screen was a little pink, so I color calibrated. But when I re-boot it jumps back to the pink profile just after re-booting. How do I save the calibration after adjusting and how do I get it to stick? I've never used color calibration before...
General Discussion
Reset/Reverse/Undo Color calibration?
I used the color calibration to change the gamma from default and now I want to change it back... how do I reset/undo the changes I made with color calibration to default/stock?
Customization
When I run the Display Color Calibration to alter the gamma cos it is too bright for me, It resets after any reboot or shutdown is there any way to keep the adjusted setting after shutdown/reboot ? Andy
General Discussion
Color Calibration, problem.
Dear all, I have Windows 7 Professional 32-bit RTM (build 7600) (latest updates) I went to Personalize> Display> Calibrate color> I then calibrated my color be decreasing the gama etc etc etc, and it works fine. but if i restart my computer all that i have done resets back to default....
General Discussion
Windows 7; Need 32 bit Color Calibration
I need 32 bit color to calibrate color & run windows media center; and my video card is not compatible with display driver model WDDM. All my settings & adjustments make everything way too big or way too small and blurry in windows 7. I'm set up with dual boot xp-sp3 and windows 7 build 7000. ...
Graphic Cards
