Recovery Partition - Create
   Warning
THIS IS NOT INTENDED TO REPLACE YOUR WINDOWS 7 DVD, HARD DRIVES FAIL, AND YOU SHOULD ALWAYS HANG ONTO THE DISK, THIS IS SIMPLY TO SPEED UP THE PROCESS OF REINSTALLING OR DOING A RECOVERY
This recovery partition will only be available to you assuming that your bootmanager is in tact, if it becomes corrupted it will be inaccessible just like your copy of windows, another good reason for hanging on to the original disk
it is recommended that you allow windows to create the 100MB System reserved partition upon installation if you plan to do this or you will have to repeat it everytime you reinstall
1. Download Easy BCD 2.0 from here: EasyBCD 2.0 Beta Builds - The NeoSmart Forums (you will need to register on the forum first)
2. open disk management, (type "partition" into the start menu its the first option that comes up)
3a Right click a partition with free space, and click "Shrink Volume" when it asks you to select how much space to shrink by allocate 4GB or 4096MB
3b Right Click the Unallocated Space and Click "New Simple Volume"
4. click ok through the next few screens, i recommend assigning it letter Z:\ so you dont get confused and accidentally delete it or save other files here
5. place your Windows 7 DVD in your drive and go to Computer, right click and then click Open
NOTE: At this point please make sure you have "hide protected operating system files" DISABLED as it occasionally corrupts the copy, to do this press alt in any explorer window, then click tools>folder options>views>hide protected operating system files.
6. Copy the entire contents of the DVD to your Z:\ Partition
7. open Easy BCD and click "add/remove entries" click the tab labelled WinPE,
When it asks for a path browse to "Z:\sources\boot.wim" and click ok, then click "add new entry"
NOTE: At this point there is a good chance easybcd will tell you that the operation failed, just click ok and do it again, from what i can see this is simply its way of asking if your sure, and it will work 2nd time around.
8. thats it your done, when you reboot you will have 2 options, Windows 7, and NST WinPE Image, NST WinPE image is your recovery partition and will act as if you'd put the disk in.
It has come to my attention that Windows has an annoying habit of corrupting the Recovery Partition, especially after Disk Cleanups and Defrags. To get around this Open Disk Management (type it into the start menu) and right click your Recovery Partition, remove the letter so that windows cant see it any more. (Don't worry it will still boot, this just stops Windows from writing files to it)
This tutorial is the intellectual property of (c)2009 Martin Joy a.k.a severedsolo and is only authorised to be hosted on sevenforums.com This tutorial is not to be copied without my explicit consent and when consent is granted the original author must be credited along with a link to this tutorial
That's correct, it's plugged into the back of the computer. I don't mean to hijack this thread so I'm happy to post about this issue elsewhere if I need to.
Do you have a wired mouse and keyboard USB or ps2 that you can use.
ME/XP/Vista/Win7
ME/XP/Vista/Win7
I'm an idiot. That's the simple solution to my problem. I don't have a wired keyboard but I'll get my hands on one if I ever need to use the recovery. Thanks, theog.
Absolutely perfect. I have wondered how this was done for a long time now and at long last it's explained. Thank you ;)
1 question I have is: How do companies like HP and Dell etc etc add software to there recovery partitions so when you reinstall windows 7 it installs the software to...?
Would be very interesting if someone could explain how its done and is it possible we could do it ourselves....?
Thanks again for your tutorial ;)
Windows 7 Pro x64AMD Athlon 64 x2 Dual Core Processor 5000+ 2....8 GigGeForce GT 240
HP Pavilion Case
Windows 7 Pro x64
AMD Athlon 64 x2 Dual Core Processor 5000+ 2.60 GHz
Pegatron - Violet 3.02
8 Gig
GeForce GT 240
Realtek HD
26 Inch and 19 Inch Dual Monitor
1920 X 1200 -- 1440 X 900
Internal 500 GB Sata Drive and 1TB Hatachi External HD & 1TB Western Digital Network Drive
550 Watts
HP Pavilion
4" and 5" Fans
Logitech Solar K750
Microsoft Wireless 3500
50 Meg Fibre Optic Cable Broadband
Samsung DP-U350 - 23" Touch Screen PC
To my knowledge most companies take their "Ideal" Machine then capture an image of that machines files and use a tool called ImageX from Microsoft to distribute it during install ;)
What is ImageX?
As for doing it yourself it might be possible , haven't really thought about it but I would stick to System Images as they are easier to manage :)
Some companies and schools use the same thing or they might use a .wim Image on a network which is like a really big ISO file
Josh
Windows 7 Professional x64 SP1 ; Windows Serv...Intel Core i5 2400 @ 3.10GHz8.0GB DDR3 @ 665MHz (2GBx4)AMD Radeon HD 6870
Foxconn H67MP-S/-V/H67MP
AMD Radeon HD 6870
AOC 2243W & SMB1930NW
1440x900 & 1920x1080
977GB Seagate ST31000524AS ATA Drive (SATA)
250GB WD iSCSI attached Drive
750W Gaming PSU
Novatech Night
Fan
Dell Standard PS/2 Keyboard
R.A.T 07 Gaming Mouse
Download: 10 Mbps Ping: 30ms Upload: 0.81 Mbps
Optiarc DVD RW AD-5260S ATA Device
What is ImageX?
Josh
Thanks Josh I always wondered what they did to add certain software to the partitions. What I was thinkinf of is adding office 2010 and see if it would install when I next run the partition. Also Adobe Master Suite CS5 because there pretty big programs and I always hate installing them. :confused:
HP Pavilion Case
Windows 7 Pro x64
8 Gig
GeForce GT 240
Realtek HD
550 Watts
HP Pavilion
4" and 5" Fans
Logitech Solar K750
What is ImageX?
Josh
It IS possible, but honestly... not really worth it. You can add programs to the recovery partition/iso using this: Welcome to RT Se7en Lite - Slipstream Service Pack,Integrate Updates,Integrate Drivers,Integrate LP,Remove Components,Enable or Disable features,Unattended Setup,Apply Tweaks,Add Icons,Wallpapers,Themes,Bootable USB or DVD but really all it does, is just install the programs after installation is completed. Its no quicker than doing it yourself.
Windows 10 Pro x64Intel Core i5 7400 @ 3.00GHz8GB 2133Mhz DDR4 (OEM supplied)Gygabyte Windforce GTX 1050Ti (Factory Overcl...
OEM supllied with PC
Realtek
Acer Al1980 + HKC
1TB Toshiba
1TB WD Caviar Green
120GB Samsung Evo 840
OEM Supplied
Logitech Wireless
Logitect Wireless
40Mb/s Down 10Mb/s Up
Defender
The best way is to get your system setup how you like it and get an image backup.
This free backup program works very well: Macruim Reflect
Any problems and you can restore your backup image and your system will be exactly how it was the day you took the backup image, all programs installed etc.
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
Thanks guys for your help, I will get it running exactly how I want it and try it next time I have to reinstall. I done a clean install a few days ago now after getting BSoD and not being able to put it right so clean install was the only answer.
Again thank you for your help ;)
HP Pavilion Case
Windows 7 Pro x64
8 Gig
GeForce GT 240
Realtek HD
550 Watts
HP Pavilion
4" and 5" Fans
Logitech Solar K750
I would just like to thank you for the great write up .
It helped me get a friends laptop back up in good working order after a hard drive crash.:party:
windows vista home 23bit
When I choose windows 7 recovery, is freeze the PC. Why? GPT is supported??
Windows 7 Enterprise SP1 x64i5-3570K @ 3.6 GhzGskill Ripjaws X 1600 @ 9-9-9-24-2NVTX3D HD 7770 @ 1100/1250
i5-3570K @ 3.6 Ghz
H61M-DGS
BenQ G922HDL
1366x768
Crucial M4 SSD 128GB
Samsung F3 Spinpoint HD103SJ 1TB
Bequiet! L8 430W
LianLi PC-7F
To be perfectly honest I've never tried this with GPT, it may not work. I don't even know if EasyBCD supports GPT
Realtek
Acer Al1980 + HKC
1TB Toshiba
1TB WD Caviar Green
OEM Supplied
Logitech Wireless
Logitect Wireless
Defender
I am not understanding Step 3a. Can someone explain it to me?
Windows 10 Home 64-bitAMD E-350 Zacate 40nm Technology4 GB DDR3 Memory1909MB ATI AMD Radeon HD
Acer 5250-0450
Acer HMA51-BZ (Socket FT1)
4 GB DDR3 Memory
Conexant High Definition Audio
Generic PnP Monitor (1366x768@60Hz)
320 GB HDD
ONN Wireless Mouse
Norton Internet Security Online
Microsoft Edge, Internet Explorer 11, and Google Chrome
Other Computers:
Laptop: Acer Aspire 5749 Series
Desktop: Acer Aspire XC603G Series
Jesse, when you have disk management open, right click and choose shrink in the context as shown here
Windows 10 Pro X64Intel(R) Core(TM) i5-3570K CPU OC@ 4.5GHZ Turbo8.00 GB DDR3 1600MhzMSI Gaming X GTX 1070
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Realtek High Definition
Dell S23O9W, HP L1710
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
MSI DS100 Interceptor
50 down and 5 up
Chrome, IE 11
Logitech X-620 Speakers
Dude, I will send you a screenshot of my disk management. This way you can tell me which one I need to choose.
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Dude, which of these partitions do I need to choose?
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Read through the steps. I suggest looking up videos to watch too
Dude Build
Windows 10 Pro X64
MSI Z77A-G45 Gaming
Seasonic X650 GOLD
Zalman Z12
Antec Kuhler 920
50 down and 5 up
Chrome, IE 11
Okay
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Acer 5250-0450
4 GB DDR3 Memory
320 GB HDD
ONN Wireless Mouse
Other Computers:
Hi. I am new here. ����
Its 2021. And I just found this forum and Win7 Recovery tutorial. And the end is I just did it to my Win7. ��
All WindowsIntel Pentium 4, Core Duo, Celeron3, 3, 2Internals
HP, Toshiba, Lenovo
All Windows
Internals
HDD
AVG Free, Avast Free, SMADAV
