Library - Include a Folder
  1. Posts : 72,058
       #20
    Sorry, Favorites doesn't have a folder tree available since they are just links instead.
    I tried adding Favorites as a library folder for this, but Favorites is not allowed to be a Library.
  2. Posts : 30
    Window 7
       #21
    Well, drat. Oh well, maybe in final release.
    Thanks for trying to help. Really appreciate it.
    Regards,
    Larry
  3. Posts : 72,058
       #22
    Hi Larry,
    Jacee had suggested to me a workaround that may work for you. You can create a new library named My Favorites, and you can copy and paste the shortcuts you want in there to use as Favorites with a folder tree. Afterwards, you can even change the library icon to the star to match. These are two icon locations that you can use for it:
    Folder with star:
    C:\Windows\System32\imageres.dll,-1020
    Star by itself:
    C:\Windows\System32\imageres.dll,-1024
  4. Posts : 30
    Window 7
       #23
    Well, that looks easy enough. I have to give it a try over the weekend and let you know.
    Thank you very much to you Brink and Jacee for all your help. I really like Windows 7, but there's just a few niggles that I don't fully understand yet, but I'm getting there. Can't wait for the full release.
  5. Posts : 72,058
       #24
    You're welcome Larry. :)
  6. whs
       #25
    Question: Has anybody figured out how to include a folder that sits on a removable device?
  7. Posts : 72,058
       #26
    Hello Wolfgang,
    It appears that it may not be possible. It says this in Help & Support:
    However, I get this when trying to do so with a USB flash drive even though it is as it states above.
  8. whs
       #27
    Yeah, they are lying. I got the same message and mine appears in Computer. But thanks Shawn for looking at the problem.
  9. Posts : 72,058
       #28
    LOl, yeah someone messed up.
  10. Posts : 2
    Folders
    Problem:
    When you add folders for your libaries, you add the subfolders, not the folder itself. Is it possible to add the folder, not the contents of the folder?
    Extra information:
    I am trying to sync my skydrive/school folder with MyDocuments folder. I can not sync the skydrive folder, because there are pictures in the skydrive folder itself, but if I add the school folder, MyDocuments folder gets flooded with folders, because there are a lot of them (unfortunally :) ).
    Thank you,
    Newnottakenname
