Library - Remove a Included Folder
    How to Remove an Included Folder from a Library in Windows 7
    This will show you how to remove an included folder so that it's contents will no longer be included in a library in Windows 7.
    Libraries let you access and arrange items from one or more folders quickly without moving them from their original location. Libraries themselves don't store your files or folders. Instead, they point to different locations on a hard disk or external drive attached to your computer. This gives you easy access to a category of files no matter where they are stored. For instance, if you have music files on your hard disk and on an external drive, you can access all of your music files from within the "Music" library.
    For more information about Windows 7 Libraries see:
       Tip
    The full path to the hidden Libraries folder is below.
    C:\Users\(User-Name)\AppData\Roaming\Microsoft\Windows\Libraries
    OR
    %AppData%\Microsoft\Windows\Libraries
    Here's How:
    1. Open the Start Menu.
    2. Right click on the User Name button and click on Open. (See screenshot below)
    3. From the Library Properties Page
    A) Right click on the library (ex: Music) that you want to remove the included folder from, and click on Properties. (See screenshot below)
    B) Select (highlight) the included folder you want to remove from the library, and click on the Remove button. (See screenshot below)
    D) Click on OK. (See screenshot above)
    E) Go to step 6.
    4. From Inside the Library
    A) Open the library (ex: Music) that you want to remove the included folder from. (See screenshot below step 3A)
    B) Click on the # locations toolbar button. (See screenshot below)
    C) Select (highlight) the included folder you want to remove from the library, and click on the Remove button. (See screenshot below)
    E) Close the library window when done. (See screenshot below step 4B)
    F) Go to step 6.
    5. From the Navigation Pane
    A) Click on the drop down triangle to the left of the Library, that you want remove a included folder from, to expand it. (See screenshot below step 5B)
    B) Right click on the included folder (subfolder) under the library, and click on Remove Location from library. (See screenshot below)
    6. Close the Libraries window when done. (See screenshot below step 3A)
  1. Posts : 21
    Windows 7 Home Premium 64-Bit
    THANK YOU! I could not figure out how to do it, was starting to pull my hair out! Thanks again,
    By the way there's a misspelling on the "Note" part of the page. "from their original locatation"
    Just want to keep your kick ass site in good shape
  2. Posts : 72,051
    You're welcome DBsantos.
    OOPS, typo corrected. Thank you.
  3. Posts : 8
    Windows 7 Pro
    Anyway to remove the Public Folders in the Libraries via GPO?
  4. Posts : 72,051
    Hello Scott,
    Not that I'm aware of. You can remove them using the method in this tutorial to each of the 4 default Libraries. :)
  5. Posts : 8
    Windows 7 Pro
    I agree and it does work but when you are building hundreds of Windows 7 computers the more you can do via GPO the better.
  6. Posts : 72,051
    I can understand that.
  7. BFG
    Windows 7 Professional 32 Bit
    I guess this is just the way things are but here's what I noticed.
    Example:
    Even though there's a pictures library and the properties says optimize for pictures, it still displays every file from folders that you include in that library.
    I was hoping I could add folders to a library like the pictures library and only have pictures appear, but no.
    If anyone knows a way to set this up let me know, but I'm thinking there isn't.
  8. Posts : 72,051
    Hello BFG,
    About the only way that I know of is to only have images in the folders that you include in the library instead.
  9. Posts : 9
    XP pro x32, 7 x32 & x64 mostly Ultimate but some times anothers
    Hello I figured out a way for changing configuration in several PC like remove the Public Folders in the Libraries if you make the change just like explained in this post you can copy the files *.library-ms at %AppData%\Microsoft\Windows\Libraries but if you edit any of this files you will notice that it is a xml and have a field <ownerSID> so I think it will only work in cloned PCs but I had no tested yet cuz I will need a way to do this with different PCs if someone know another way via command line, registry, GPO, please post
    regards
