Burn Disc Image - ISO or IMG file
Page 1 of 6 123 ... LastLast
    How to Burn a "ISO" or "IMG" Disc Image file to a CD/DVD in Windows 7 and Windows 8
    This tutorial will show you how to use the built-in Windows Disc Image Burning Tool to burn a ISO or IMG disc image file to a CD/DVD in Windows 7 and Windows 8.
       Warning
    Windows Disc Image Burner will need to be set as the default program with all of it associations (.iso & .img) set to it for this to work. It is by default in Windows 7 and 8.
    Here's How:
    1. Place a blank unformatted CD or DVD into your CD/DVD drive, and do step 2 or 3 below.
    NOTE: If a AutoPlay window opens with the option to format the CD/DVD, then just close it.
    2. Right click or press and hold on the ISO or IMG file that you want to burn to CD/DVD, click/tap on Burn disc image, and go to step 4 below. (see screenshot below)
    3. In Windows 8 File Explorer, select (highlight) the .iso or .img file that you want to burn to CD/DVD, click/tap on the Manage (Disc Image Tools) tab and on Burn button in the ribbon, and go to step 4 below. (see screenshot below)
    4. Next to Disc burner, click/tap on the drop down arrow and select the CD/DVD drive with the blank CD/DVD in it. (see screenshot below step 4)
    5. Check the Verify disc after burning box if you want Windows 7 to verify the disc image afterwards, otherwise leave it unchecked. (see screenshot below)
    NOTE: Verifying the disc will take a little bit longer for the disc image to be finished.
    6. You will now see this. (see screenshots below)
    7. If you checked the Verify disc after burning box in step 5, then you will see this next. (see screenshot below)
    NOTE: You will not see this if you did not check the box. Instead you will see step 8.
    8. When it is finished burning the disc image, click/tap on the Close button. (see screenshot below)
    9. Remove your new burned CD/DVD image from the CD/DVD drive.
  1. Posts : 1,027
    Windows 7 Ultimate x64/ Windows Vista Ultimate x64
    This is nice don't need any 3rd party software. Thanks Shawn keep them coming.
  2. Posts : 72,043
    You're welcome Mansrm. Thank you to John (z3r010) for finding this feature.
  3. Posts : 1,633
    Win 7 Ult SP1/Win 10 Pro (all x64)
    How come I don't have that option in my right-click?
  4. Posts : 72,043
    Hello Peter,
    Are you right clicking on a .img or .iso file? It will only appear for these file types.
  5. Posts : 1,633
    .iso. I have several stored on my various drives and they all just start with the option to open, take ownership and so on.
    Under default programs, associate a file type......etc. it isn't even listed as a file type.
  6. Posts : 1,633
    However....if I double-click one of .iso files this comes up....
    Attached Thumbnails Attached Thumbnails Burn Disc Image - ISO or IMG file-capture.jpg
  7. Posts : 72,043
    If you had installed some other 3rd party disc image program, it may have unset the default Windows Disc Image Burner that Windows 7 uses. In Default Programs, check to make sure that Windows Disc Image Burner is set as the default program with all of it's associations set to it as well.
  8. Posts : 1,633
    You hit the nail on the head. Although it appeared if I double-clicked a .iso it had 0 of its 2 defaults in Default Programs.
    Now that I specified them it shows in the right-click too.
    Thanks.
    Not sure why that had come undone.
  9. Posts : 72,043
    Peter,
    I'm happy to hear that you got it back now. My only guess is some 3rd party program may have unset it.
