Backup User and System Files
Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
  1. Posts : 560
    WIN10
       #110
    brink,
    im sorry if you answered this already but i had a problem with this backup before and gave up and used macrium. i want to give windows 7 back up another go..
    on my secondary hard drive i created a partition thats 30GB, i figured that was enough for me if i only do monthly backups and just delete the old one after a new backup was done. i successful completely a backup and its only 2.11GB in size.
    if i had a complete hard drive failure on my primary hard drive that holds my C drive and 100MB of system reserved. will these backups do anything for me. like would i be able to reload windows 7 to the point in which that backup was created on a secondary drive.
    if not as i suspect, then whats the point? i see something about a system image? thats probably something i wanna do. i skip that step when i was doing the backup..
    looks like i have to create a system image backup, is there no compression to this system image backup, my C drive has about 40GB being used and for the system image backup it needs that amount of space.. i guess its physically copying everything to that image.. how would this ever be put on a CD or DVD then..
  2. Posts : 72,052
       #111
    Hello Eldinv,
    You are correct. You would need to create a system image instead to be able to restore Windows 7 with it to how it was when the image was created. Unfortunately, there is very little compression for the backup system image file.
    It could take quite a few DVDs if they were used instead. This would be why using a HDD or another partition would be preferred and more reliable. The system image is a complete copy of the selected drives.
  3. Posts : 560
    WIN10
       #112
    Brink said:
    Hello Eldinv,
    Thanks again for the reply, guess i have to stick with macrium... i cant believe the system image file cant be better compressed...such a waste of hard drive space. i can copy the whole c drive including data and the back file is only a fraction of space. i dont know whats going on, what do u suggest.
  4. Posts : 72,052
       #113
    I would recommend a good free 3rd party HDD image program like Macrium Reflect instead.
  5. Posts : 23
    Hello!
    Is there any way to change the default limit of 30% of disk space for backups? I keep my backups on a 1TB hard drive, and definitely don't want them to use over 300 GB.
    Also, as I can see, Windows only makes incremental backups for several days, then it creates a new full backup. Is there any way to automatically delete the previous full backup after a new one is made? This would be a better alternative to changing the backup size limit.
  6. Posts : 72,052
       #115
    Hello Rathori,
    Sorry, but the sizes or how backups are made cannot be changed. You might consider trying the free program Macrium Reflect instead to be able to do this.
  7. Posts : 23
    Thanks for your fast reply!
    I'd try the program, just had to make sure this was not possible with built-in B&R utility.
  8. Posts : 72,052
       #117
    No problem, but not that I'm aware of.
  9. Posts : 6
    Good info here! Thanks!
    To be sure I'm clear on one of the topics:
    I like to regularly back up my photo files to 2 external hdd's. I think I saw that they cannot be done simultaneously? Would it be easier to just do a manual 'Backup Now' for each, as opposed to setting up 2 different backup jobs? Or better yet perhaps, how would you suggest I do it?
    Oh, and I don't keep my externals powered on until I want to do a backup.
    I've tried one third party backup program - Lacie - hated how it worked and found it easier to just copy the new stuff/changes to my externals.
    I hope that makes sense. :)
  10. Posts : 72,052
       #119
    Hello Hamilton,
    Since it's only photo files, it may be easier to just copy and paste them to your external drive as a backup. You could add "Copy to Folder" and "Move to Folder" to make doing this easier if you like.
    This way you could keep your external HDD's turned off until needed.
