Details Pane - Turn On or Off
    How to Turn the Details Pane On or Off in Windows 7
    You can use the details pane in Windows Explorer to see the most common properties associated with the selected file. File properties are information about a file, such as the author, the date you last changed the file, and any descriptive tags you might have added to the file. The details pane is turned on by default in Windows 7.
    The details pane only shows the size of 15 selected items by default and viewing the total size of more than 15 selected items requires clicking on the Show more details link each time the selection changes.
    This will show you how to turn the Details pane on or off in all Windows Explorer windows in Windows 7.
       Tip
    When the Details pane is turned on, you can drag it's top border line up and down to increase or decrease the size of the Details pane.
    EXAMPLE: Windows Explorer Layout
    NOTE: The details pane is the bottom pane in Windows Explorer.
    OPTION ONE
    To Turn "Details Pane" On or Off in Windows Explorer
    1. Open Windows Explorer (explorer.exe).
    2. On the toolbar, click on Organize and Layout. (see screenshots below)
    3. To Turn On the Details Pane in Windows Explorer
    A) Select (click) Details pane to have it checked. (see screenshots above)
    4. To Turn Off the Details Pane in Windows Explorer
    A) Select (click) Details pane to have it unchecked with the icon now showing. (see screenshots above)
    5. All Windows Explorer windows will now open as you set this.
    OPTION TWO
    To Turn "Details Pane" On or Off using a REG File Download
    1. To Turn On the Details Pane in Windows Explorer
    Turn_Details_Pane_On.reg
    Download
    B) Go to step 3.
    2. To Turn Off the Details Pane in Windows Explorer
    Turn_Details_Pane_Off.reg
    Download
    4. Right click on the downloaded .reg file, and click on Merge.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. Close and reopen any open Windows Explorer window to apply.
    7. When done, you can delete the downloaded .reg file on the desktop if you like.
  1. Posts : 89
    Win 7 x64
    Isn't there a keyboard shortcut to toggle the details pane, just as there is alt+P for the preview pane ???
  2. Posts : 72,043
    Hello soewhaty, :)
    Close. It would be Alt+Shift+P to toggle the details pane.
    EDIT: Nope, that's only in Windows 8/10.
  3. Posts : 89
    Win 7 x64
    Yeah .. i saw that one somewhere and tried it, but mysteriously for me that shortcut toggles the Preview pane, not the Details pane ... i don't know why ... I already have a fine shortcut for toggling the Preview pane and that is alt+P, so why Alt+Shift+P now toggles again the Preview pane and not the Details pane is a mystery to me. Any idea?
  4. Posts : 89
    Win 7 x64
    Very frustrating ...
  5. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    Tab key is the only way I've ever gotten to the organize menu list :)
  6. Posts : 89
    Win 7 x64
    yeah but @Brink ... why doesn't Alt+Shift+P work .. makes no sense?????
    it's too long and tiresome to do it with Tab ...
  7. Posts : 72,043
    It just wasn't coded to do so.
    I'd just leave it turned on to avoid the frustration if you're always turning it off and on.
  8. Posts : 89
    Win 7 x64
    Ermmm ... alright .. not really sure i followed u there ... isn't Alt+Shift+P by default supposed to toggle the Details pane (at least that's what i though you suggest by your 1st reply to my question) ... or do I have to code it to do that?
    So that's it ... no other way? Strange ...
    Well yeah ... it's annoying but ok... if no keyboard shortcut exists then it has to be done with the mouse ...
  9. Posts : 72,043
    No, Alt+Shift+P is only in Windows 8/10 from the edited post.
    There is not a keyboard shortcut to toggle the Details pane in Windows 7.
