How to Allow or Prevent Changing Screen Saver in Windows 7 and Windows 8
InformationThis will show you how to allow or prevent all or specific users on the computer to add, configure, or change the current screen saver in Windows 7 and Windows 8.
This does not prevent a screen saver from running.
You must be logged in as an administrator to be able to do the steps in this tutorial.
EXAMPLE: Screen Saver in Personalization
NOTE: This is Screen Saver changes allowed (left screenshot below) and prevented (right screenshot below) in Personalization.
OPTION ONEAllow or Prevent Changing Screen Saver using a REG File Download
1. To Allow Changing Screen Saver for All Users
A) Click/tap on the Download button below to download the file below, and go to step 3 below.2. To Prevent Changing Screen Saver for All Users
Allow_Changing_Screen_Saver.reg
A) Click/tap on the Download button below to download the file below, and go to step 3 below.3. Save the .reg file to your desktop.
Prevent_Changing_Screen_Saver.reg
4. Double click/tap on the downloaded .reg file to merge it.
5. Click on Run, Yes, Yes, and OK when prompted.
6. Log off and log on, or restart the computer to completely apply.
7. When finished, you can delete the downloaded .reg file if you like.
OPTION TWOAllow or Prevent Changing Screen Saver using Group Policy Editor
1. Open the all users, specific users or groups, or all users except administrators Local Group Policy Editor for how you want this policy applied.That's it,
2. In the left pane, click on to expand User Configuration, Administrative Templates, Control Panel, and Personalization. (See screenshot below)
3. In the right pane, double click/tap on Prevent changing screen saver to edit it. (See screenshot above)
4. To Allow Changing Screen Saver
A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)5. To Prevent Changing Screen Saver
B) Go to step 6.
A) Select (dot) Enabled. (See screenshot below step 6)6. Click/tap on OK. (See screenshot below)
Related Tutorials
- How to Turn Screen Saver On or Off in Windows 7
- How to Change the Screen Saver in Windows 7 and Windows 8
- How to Create a "Screen Saver Settings" Shortcut in Windows
- How to Enable or Disable Screen Saver Password Protection in Windows 7 and Windows 8
- How to Allow or Prevent Changing Sounds in Windows 7
- How to Allow or Prevent Changing Desktop Background in Windows 7
- How to Specify a Desktop Background for All Users
- How to Allow or Prevent Changing Window Color and Appearance in Windows 7
- How to Allow or Prevent Changing Theme
- How to Allow or Prevent Changing Mouse Pointers in Windows 7
- How to Specify a Default Theme to Load for New Users in Windows 7
- How to Set or Change the Screen Saver Timeout Period in Windows 7
- How to Specify a Default Screen Saver for All Users in Windows 7
- How to Enable or Disable Screen Savers in Vista, Windows 7, and Windows 8
