Recycle Bin Properties - Add or Remove
    How to Add or Remove "Properties" from Recycle Bin Context Menu in Windows
    The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full.
    This will show you how to add or remove Properties from the Recycle Bin desktop icon's context menu for specific or all users in Vista, Windows 7, or Windows 8.
    You must be logged in as an administrator to be able to do the steps in this tutorial.
    EXAMPLE: Recycle Bin Properties
    Recycle Bin Properties - Add or Remove-rb_context_menu.jpgRecycle Bin Properties - Add or Remove-rb_properties.jpg
    OPTION ONE
    Add or Remove "Properties" from Recycle Bin using REG File Download
    NOTE: This option will affect all users on the PC.
    1. To Add "Properties" to Recycle Bin Context Menu
    A) Click/tap on the Download button below to download the file below, and go to step 3 below.
    Add_Recycle_Bin_Properties.reg
    2. To Remove "Properties" from Recycle Bin Context Menu
    Remove_Recycle_Bin_Properties.reg
    4. Double click/tap on the downloaded .reg file to merge it.
    5. When prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve merging the .reg file.
    6. Log off and log on, or restart the computer to completely apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Add or Remove "Properties" from Recycle Bin in Local Group Policy Editor
    2. In the left pane, click/tap on to expand User Configuration, Administrative Templates, and Desktop. (See screenshot below)
    3. In the right pane, double click/tap on Remove Properties from the Recycle Bin context menu to edit it (See screenshot above)
    4. To Add "Properties" to Recycle Bin Context Menu
    A) Select (dot) either Not Configured or Disabled, and go to step 6 below. (See screenshot below step 6)
    5. To Remove "Properties" from Recycle Bin Context Menu
    A) Select (dot) Enabled, and go to step 6 below. (See screenshot below step 6)
    6. Click/tap on OK. (See screenshot below)
    8. Log off and log on, or restart the computer to completely apply.
  1. Posts : 13,354
    Windows 7 Professional x64
    Good tutorial, Shawn.
    Just out of curiosity, why would anyone want to do this?
  2. Posts : 72,052
    Hello Jonathan,
    It's mostly for those that need to restore it when it was unknowingly removed somehow, but it can be helpful if you do not want other users on the computer to be able to change the settings in the Recycle Bin properties page from what you have it set as.
  3. Posts : 201
    Win-7HP, VistaHP, XP
    Great tut and .reg Brink
    I have one done one for removing the recycle bin all together but dont need it now anymore not with win7 options. Since now has setting to hide / remove :)
