Windows 7: Desktop Background - Allow or Prevent Changing
23 Nov 2012   #10
Brink
64-bit Windows 10 Pro
Hello Randun,
Here's a few more things to check to hopefully help.
Normally you would delete the NoChangingWallPaper DWROD, but 0 should work as well.
Check in the registry location below to make sure that there is not an ActiveDesktop desktop key there.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies
Make sure that your Windows is activated. If it's not, and goes past it's trial period, you will get a black screen like this as well.
23 Nov 2012   #11
randun
Windows 7 Home Ultimate 64-bit
Quote   Quote: Originally Posted by Brink View Post
Hello Randun,
I picked up the first tweak from another forum & 0 didn't have any effect.
No ActiveDesktop at the specified registry entry.
My version of Windows (7 Ultimate) is verified as "activated".
I did look under Themes under the same registry entry & CurrentValue was set to C:/... as My Themes. I backed up the registry then changed the entry to (current value empty). I haven't rebooted yet so I'll have to come back & report on it.
24 Nov 2012   #12
randun
Quote   Quote: Originally Posted by randun View Post
Hello Randun,
Well, I tried all of your suggested fixes along with numerous others & I've had it. I'm not about to perform a System Repair so I'm downloading a trial version of WindowBlinds to see if it'll work.
15 Nov 2015   #13
Deltron0
Windows 10
THANKS!!
Seriously been trying to fix no changing the background for several hours. Tried the Ease of Access, Registry, and Gsedit.msc. None worked! Option One in this thread worked like magic!!!
I made an account on this only because you helped out so much. I'll tell all my friends having trouble with windows to check this site out.
15 Nov 2015   #14
Brink
I'm glad it could help Deltron, and welcome to Seven Forums.
Desktop Background - Specify and Prevent Change
How to Specify a Desktop Background for Users in Windows This tutorial will show you how to specify a BMP or JPG image of your choice as the default desktop background wallpaper for all or specific users in Vista, Windows 7, and Windows 8. You will also be able to specify that the...
Tutorials
Any fix to prevent wordpad from background image?
I know about setting the application background color to white. Regardless of what color it is set at, it will still print the background color. Just setting it to white, will just hide that it is still printing the background. Microsoft shouldn't have put that feature on/in wordpad, it...
General Discussion
Desktop Background disappeared after changing the pc performance
After changing the performance to play my game I changed it back and the background disappeared. It Comes back when I force shut Explorer.exe and gone again after i restart explorer.exe
General Discussion
problem in changing desktop background
Hi i'm using sony vaio windows 7 in-built,i cant able to change my desktop background it got stucked with my old wallpaper and another problem is that my catalyst control is showing an error (catalyst working stopped). please help me to fix these errors. Thank you so much in advance!
General Discussion
I'm having trouble with changing my desktop background
I'm new here so i'm not sure where I should be putting this topic to so if i have it wrong please let me know where I should put it to. Anyways I'm having trouble with changing my desktop background. My laptop is a Toshiba and I use windows 7. I've tried changing it but it won't work and when i...
Customization
How to identify, stop and prevent background processes?
Hello there! I recently had an occasion to go to the DOS, well the "command prompt" as it is called now, and executed a command, which I think was called Tasklist. It listed an enormous list of processes that were running on my computer. Things like the Adobe updater, Apple phone support, etc....
Performance & Maintenance
