How to Create a Windows Experience Index Shortcut in Windows 7
This will show you how to create or download a
Windows Experience Index (WEI) shortcut that opens to the
Performance Information and Tools window. You can also
Pin to Taskbar or
Pin to Start Menu this shortcut, or move where you like for easy use.
EXAMPLE: Windows Experience Index
OPTION ONE
Download the Shortcut
1. Click on the Download button below to download the file below.
Windows_Experience_Index.zip
2. Click on Save, and save the .zip file to the desktop.
3. Open the .zip file and extract (drag and drop) the Windows Experience Index shortcut to the desktop
4. Right click on the extracted
Windows Experience Index shortcut, and click on
Properties,
General tab, and on the
Unblock button. (See screenshot below)
5. Move the shortcut to where you like for easy use.
6. When done, you can delete the downloaded .zip file if you like, or save it to use again.
OPTION TWO
Manually Create the Shortcut
1. Right click on a empty area on desktop, and click on
New and
Shortcut. (See screenshot below)
2. Type the location below into the location area, and click on the
Next button. (See screenshot below)
C:\Windows\explorer.exe shell:::{78F3955E-3B90-4184-BD14-5397C15F1EFC}
3. Type
Windows Experience Index for the name, and click on the
Finish button. (See screenshot below)
NOTE: You can name this anything you would like though. 4. Right click on the new
Windows Experience Index shortcut on the Desktop and click on
Properties.
5. Click on the
Shortcut tab, then click on the
Change Icon button. (See screenshot below)
6. In the line under "Look for icons in this file", type in the location below and press
Enter. (See screenshot below)
C:\Windows\System32\PerfCenterCPL.dll
7. Select the icon highlighted in blue above and click on
OK. (See screenshot above)
NOTE: You can use any icon that you would like instead though.
8. Click on
OK. (See screenshot below)
9. Move the shortcut to where you like for easy use.
